jimpram Offline
#1 Posted : Tuesday, 3 March 2009 7:06:35 AM(UTC)
jimpram
Can any one help with Speedo setup for : VS commodore running 355 stroker with a VN SS group A twin throttle & VN computer and Turbo 350 Trans.
Is there a special adaptor that bolts onto speedo ?
In other words how do you get the speedo to work on a VS commodore running turbo 350 Trans & VN computer? Thanks..............
Time is running faster than ever before ?
Edited by user Tuesday, 3 March 2009 7:33:18 AM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 3 March 2009 7:43:11 AM(UTC)
Yeah mate ,there is an adaptor,you can check out this forum for the answer "Byron " wrote a fully detailed conversion check it out...it has everthing including that information...
Jim in adelaide
jimpram Offline
#3 Posted : Tuesday, 3 March 2009 8:10:35 AM(UTC)
jimpram
Thanks Jim. Ill have a look and see if I can find it.
Do it now!! Time is running out.......
jimpram Offline
#4 Posted : Tuesday, 3 March 2009 8:25:46 AM(UTC)
jimpram
Had a look. Not enough info there for me.
#5 Posted : Tuesday, 3 March 2009 4:18:33 PM(UTC)
VS computer uses 10 pulse per rev speedo and so does VN so the speedo should still work. I would have thought that itd be the VN ECU thats be complaining as it wants to see 2 pulse per rev whereas the VS ECU takes 10 pulse directly. The VN speedo does the
jimpram Offline
#6 Posted : Tuesday, 3 March 2009 10:06:10 PM(UTC)
jimpram
Thanks for reply & info Byron. Much appreciated.
The car is my sons which is nearing completion. Hasnt even been started yet. Will be in two weeks time.
It was originally V6 & has been transplanted with "5.7" ltr stroker (there you go no grumbling)
#7 Posted : Tuesday, 3 March 2009 10:39:59 PM(UTC)
The grumbling isnt because people dont call then 5.7L. Its because the call them a 355 when they are a 350.
As I said, for a VN ECU you need a 2 pulse per rev speed signal, where the 2 pulse signal is derived from the dash which does the conversion fro
jimpram Offline
#8 Posted : Wednesday, 4 March 2009 2:50:15 AM(UTC)
jimpram
Thanks again Byron.
I will pass the information on to my son and see how he goes.
Since my last reply I surfed the net for info on Memcal,ECU,PCM and have aquired a better understanding.
Thanks again. Your knowledge has been of great help.
Do
playwme Offline
#9 Posted : Wednesday, 4 March 2009 7:45:55 AM(UTC)
playwme
So does the standard VS V6 sensor fit straight into a T350 gearbox??
#10 Posted : Wednesday, 4 March 2009 4:12:28 PM(UTC)
Probably not, but a VN/VP one will. In my last reply I was thinking Jim was running a VS 4L60E for some reason,
jimpram Offline
#11 Posted : Wednesday, 4 March 2009 9:44:35 PM(UTC)
jimpram
Thanks for suggestion PLAYWME, but I tried a VS V6 sensor as suggested and it does not fit into Turbo 350. To begin with the sensor Diameter is slightly larger so you cant use it as a plug off only and it is a completely different setup to a VN Trans.
Th
Edited by user Monday, 9 March 2009 1:30:48 AM(UTC)  | Reason: Not specified
#12 Posted : Wednesday, 4 March 2009 10:15:06 PM(UTC)
A VS 4L60E is the name of the 4-speed automatic transmission found in Commodores, VR onwards.
jimpram Offline
#13 Posted : Wednesday, 4 March 2009 10:17:05 PM(UTC)
jimpram
Thanks Dr Terry, But is that the same for V6 & V8?
Edited by user Wednesday, 4 March 2009 10:29:45 PM(UTC)  | Reason: Not specified
#14 Posted : Wednesday, 4 March 2009 10:48:45 PM(UTC)
Yes, different boxes but same codes. The boxes used to be called TH400, TH700R4 etc, but when the company structure changed (Dr Terry posted this up a while back), the names changed, so TH400 became 3L80, TH700 became 4L60. The E means electronic controll
jimpram Offline
#15 Posted : Wednesday, 4 March 2009 11:53:02 PM(UTC)
jimpram
Thanks for all the information. Much appreciated.
Guest (13)
