sixx Offline
#1 Posted : Monday, 19 October 2009 3:26:36 AM(UTC)
sixx
Hello, anyone got any advise, ive just put a new 950cfm race carb on my 351 and hooked up a new fuel pump and reg.
Fuel pump is pre-set to 9psi , fuel reg i have adjusted to 4psi and yet it still leaks fuel badly from front and rear power valves just under the bowls.
Could this mean the new power valves are stuffed (2) the psi is still to highor (3) needle and seat stuck?. I havent even started the car yet so this leak is just from turning it on and watching the bowls fill.
Any help would really be appreciated.
bambino Offline
#2 Posted : Monday, 19 October 2009 7:13:53 PM(UTC)
bambino
Check your float levels.
Paul351xb Offline
#3 Posted : Tuesday, 20 October 2009 2:18:08 AM(UTC)
Paul351xb
Agreed, check the floats then go from there.
"Life, a series of events, woven into a tapestry which becomes our destiny"
sixx Offline
#4 Posted : Wednesday, 21 October 2009 7:59:14 AM(UTC)
sixx
Hey guys,
yeh carby has glass sight bowls and float levels are sitting just below half way/centre of them.
any other ideas would be much appreciated.
Cheers sixx
sixx Offline
#5 Posted : Wednesday, 21 October 2009 8:01:09 AM(UTC)
sixx
Should car be running before you set the reg psi or can that be done without engine running and just activating the fuel pump ????
