coupe Offline
#1 Posted : Wednesday, 28 October 2015 12:20:30 PM(UTC)
coupe
Hi can anyone tell me if muncie inspection covers are the same as saginaw ones and are they also the same as truck?
gm5735 Offline
#2 Posted : Wednesday, 28 October 2015 12:52:18 PM(UTC)
gm5735
Muncie and Saginaw are completely different in many ways.
There are different numbers of attaching bolts in the side cover, but most importantly the reverse selector is in the side cover on a Saginaw, but in the extension housing on a Muncie.
I don't know what you mean by "The same as truck"
#3 Posted : Wednesday, 28 October 2015 3:06:24 PM(UTC)
I think he means the clutch inspection cover. These should be specific to the bellhousing not to Saginaw/Muncie/T10 as they are at the engine side of the bellhousing. I think you'll find the truck one should be the same too but these would normally be 11" or bigger flywheel.
gm5735 Offline
#4 Posted : Wednesday, 28 October 2015 4:27:17 PM(UTC)
gm5735
I think you might be right. Nothing at all to do with the gearbox.
coupe Offline
#5 Posted : Wednesday, 28 October 2015 6:08:13 PM(UTC)
coupe
Yes i mean the clutch inspection cover. It bolts to the bellhousing not the engine so thats why im asking if its the same. My bellhousing is an 11 inch one with an adaptor ring to suit the smaller front bearing retainer. I have no clutch inspection cover at all and need one for my muncie. Thanks guys.
#6 Posted : Wednesday, 28 October 2015 6:19:01 PM(UTC)
I'd say you just need an 11" one, not sure if they are different. A quick check of HK and HT/G parts catalogue will tell you if they are the same for 10.5 and 11".
coupe Offline
#7 Posted : Wednesday, 28 October 2015 6:23:03 PM(UTC)
coupe
Thanks mate ill try to find those numbers somewhere. Apparently its just the depth of the bellhousing. Its just a little fuller towards the rear of the bellhousing. If i could work out how to put up pics i would.
Edited by user Wednesday, 28 October 2015 7:12:51 PM(UTC)  | Reason: Not specified
gm5735 Offline
#8 Posted : Wednesday, 28 October 2015 10:00:46 PM(UTC)
gm5735
The 11" HT350 bellhousing is 3899621 (part number and casting number) and uses cover 38433943.
The 10.5" HK307/327 bellhousing is part number 3858402(casting number 3858404) and the cover is 3788422.
So yes, they are different.
