Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Intermediate steering shaft mocked up. Final length still needs to be confirmed once everything is fitted 100% correctly
You are a member of these groups:: Registered, Veteran
magnificent is all i will say..
Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
Originally Posted by: we wreck 81837s only  magnificent is all i will say.. Definitely this. My favorite build on this forum and the engineering involved makes me feel bad about my own stuff
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Once again, congratulations on such impressive builds, and on taking the trouble to share them with us. I wonder how you go about getting the finished product certified, with so many alterations, modifications and fabricated parts in critical areas. Do you involve the certifying engineer all the way along, or document each modification, or just present the finished product?
I shudder thinking about having to justify each and every alteration to a third party.
Originally Posted by: gm5735  Once again, congratulations on such impressive builds, and on taking the trouble to share them with us. I wonder how you go about getting the finished product certified, with so many alterations, modifications and fabricated parts in critical areas. Do you involve the certifying engineer all the way along, or document each modification, or just present the finished product?
Getting an engineer involved at stage one is a good idea. It's also a good idea to read VSB14 and the VSCCS regulations from cover to cover. These outline all the requirements in pretty plain terms. I have also done this a few times before so that makes it a lot easier..
