#1 Posted : Thursday, 28 January 2016 12:07:52 AM(UTC)
I have a tacho in the VK, with the old est distributor it worked fine but I have now fitted a hei dissy and the tacho is not working. I tried attaching the tan wire in the harness still no go, but when i connected the wiring to the coil I only connected the one pink wire to the + terminal, should I have connected the other wire to the -?
I assume if I do it won't confuse the computer/distributor.
thanks
#2 Posted : Thursday, 28 January 2016 6:19:21 PM(UTC)
Brown wire at the coil to the coil - terminal is what makes the tacho work
#3 Posted : Saturday, 30 January 2016 1:36:32 AM(UTC)
Thanks Mick. What I did was replace the coil, and run the wires from the hei dissy to the coil, with the pink wire from the ignition switch to the + terminal and the other wire from the loom just hanging loose, should I connect that to the -ve coil?
Edited by user Saturday, 30 January 2016 1:37:22 AM(UTC)  | Reason: Not specified
#4 Posted : Saturday, 30 January 2016 3:40:39 PM(UTC)
Yep - that other loose wire should be dark brown, and is the tach wire. It goes to the coil - terminal (which is the green wire from the dizzy to the coil).
