#1 Posted : Monday, 1 February 2016 7:10:30 PM(UTC)
The fuel pump relay on a VX Commodore, is the relay on all the time when the engine is running or does it switch on and off?
If it switches on and off, does it switch the + side or the - side?
Warren
#2 Posted : Tuesday, 2 February 2016 6:43:04 AM(UTC)
The fuel pump relay is on all the time the engine is running, as well as a few seconds of priming when the ignition first is switched on, before starting.
The relay is switched on its +ve side directly from the ECU (pin E10).
#3 Posted : Tuesday, 2 February 2016 5:09:53 PM(UTC)
Thanks Terry,
Warren
This page was generated in 0.017 seconds.
