David 67HR Offline
#1 Posted : Sunday, 21 February 2016 6:49:05 PM(UTC)
David 67HR
What is the difference between M20 and M21 6 Cylinder Aussie 4 Speed gearboxes, how do you tell the difference between them? What length is the input shaft from the face of the gearbox?
#2 Posted : Sunday, 21 February 2016 7:41:23 PM(UTC)
Ok, where do I begin.
The numbers M20 & M21 can refer to any number of Aussie 4-sp gearboxes, as well as Opels, Saginaws & Gemini 'boxes etc. etc.
It's best to dispense with the M20/M21 numbers & look at each gearbox type separately.
With the Aussie 4-sp there are 5 different ratio sets & 2 different lengths, the 4/6 cyl one & the longer V8 version.
The only reliable way to determine which ratio set you have is to pull off the side cover & check the part no. stamped into the cluster gear.
The most common 2 have part nos. ending in either 496 or 497.
The 496 ratio set is the most common with a 1st gear of 3.05, while the 'box with the 497 ratio has a 1st gear of 2.54.
The 497/2.54 box is 'usually' seen only behind 308 V8s but there are several exceptions, which is why I said to check each box on its own merits.
David 67HR on 24/02/2016(UTC)
David 67HR Offline
#3 Posted : Wednesday, 24 February 2016 5:01:32 PM(UTC)
David 67HR
Thanks DR Terry, a wealth of knowledge as usual
