sgo Offline
#1 Posted : Tuesday, 29 March 2016 5:03:59 PM(UTC)
sgo
In a VP wiring loom, is this the BCM, or else what is it?
thanks.
#2 Posted : Tuesday, 29 March 2016 5:21:45 PM(UTC)
Anti-theft module / BCM - used in VP Calais, VQ Series 2 stato/caprice.
Make sure you get the matching remotes for it, otherwise they are almost impossible to get programmed.
sgo Offline
#3 Posted : Tuesday, 29 March 2016 5:51:34 PM(UTC)
sgo
Thanks Mick, loom is being used in a v6 FC and seems to be all ok.
Door remotes are not in use, just manual key entry and anti theft switch works as it should.
Cheers.
#4 Posted : Tuesday, 29 March 2016 9:48:39 PM(UTC)
You can bypass it completely & remove it.
The door pillar switch has 4 wires going to it. When "on" 2 are NC and 2 are NO. When the key is turned, they reverse, so you can permanently take it out of the loop by joinging the right wires (and leaving the others open) - unless you plan on using it as a secondary key-operated immobilizer when it's parked up.
