#1 Posted : Friday, 1 April 2016 2:11:04 AM(UTC)
I've got a new old stock Holden badge for the grille and a four original GTS badges with perfect chrome but no red paint on them.
Would the original GTS badges have exactly the same red as the Holden badge?
Is enamel the only paint that actually sticks to chrome or is there some other paint I should be using?
Wayne
Edited by user Friday, 1 April 2016 2:16:23 AM(UTC)  | Reason: Not specified
#2 Posted : Friday, 1 April 2016 5:59:37 AM(UTC)
I have a NOS grille badge and GTS badge and from memory they look identical. Haven't seen them for 10 years though as they are stashed away in boxes.
#3 Posted : Friday, 1 April 2016 6:36:17 AM(UTC)
I'd be very interested to know if you ever dig them out Byron.
#4 Posted : Friday, 1 April 2016 7:20:57 AM(UTC)
I have some NOS tail-lights somewhere too with the candy-apple looking clear red on them, and a centre grille badge as well. I think I only have two GTS badges though, missing a 3rd.
#5 Posted : Wednesday, 20 April 2016 9:09:12 PM(UTC)
I answered my own question today with a nos GTS badge and nos 5Ltr badge as well as some nos wheel arch moulds, discovered all of the reds are the same.
GTS badges, Holden grille badge, GTS wheel trim emblem, even the red for the wheel arch moulds are all exactly the same red.
I've got a couple of very good HQ GTS badges here as well and even they look to be the same red.
Didnt get a photo of the HK GTS badge but it was the same.
Should be easy to match it in semi gloss.
Ausjacko Offline
#6 Posted : Thursday, 21 April 2016 12:11:30 PM(UTC)
Ausjacko
would be interested to know the paint code if you match it correctly.
#7 Posted : Friday, 22 April 2016 5:50:50 PM(UTC)
Just a test run, close but no cigar.
Needs to go slightly darker and I'll thin it out a bit next time.
I'll let you know the details when its close enough.
Ausjacko Offline
#8 Posted : Sunday, 24 April 2016 9:38:44 AM(UTC)
Ausjacko
no worries, thanks
#9 Posted : Tuesday, 26 April 2016 9:07:14 PM(UTC)
Not 100% but thats close enough for me.
I used Valspar acrylic because they have the most comprehensive colour chip folder I've ever seen, wasnt difficult to get it pretty close.
Add just the slightest amount of thinners to allow it drip off the toothe pick and flow . . . yes a toothe pick is the best way to paint it.
Make sure its a thick coating of paint, too thin and it will come off too easy.
Brand - Valspar
Series - 303C01 1K acrylic
Colour map number - S0517
Sample size - 250ml
Sample price - $20
Note: I added 10 grams of L47 flattener but that was a mistake, it dosent need it.
www.valsparrefinish.com.au/distributors
 1 user thanked RigPig for this useful post.
Ausjacko on 27/04/2016(UTC)
Ausjacko Offline
#10 Posted : Wednesday, 27 April 2016 7:45:45 AM(UTC)
Ausjacko
Looks great, thanks. I will give it a go on something I have here
HGV8 Offline
#11 Posted : Wednesday, 27 April 2016 7:04:12 PM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
A method I have used for dispersing the paint on badges and hubcap centres is a hypodermic needle.
Bit embarrassing asking for them at the chemist though but the results are well worth it.
Jim
j.williams
Ausjacko Offline
#12 Posted : Wednesday, 27 April 2016 10:31:49 PM(UTC)
Ausjacko
Wouldn't you know it, the local supplier is out of that base. Will have some next week and I will give the 'pick' (hypo and tooth) a try.
Ausjacko Offline
#13 Posted : Thursday, 12 May 2016 7:52:11 PM(UTC)
Ausjacko
Did my grille badge today using the tooth pick application technique; worked great and the colour is darn near spot on. Bugger, have to get it out of the oven without the wife noticing
#14 Posted : Thursday, 12 May 2016 8:10:15 PM(UTC)
I ended up doing a thin coat of etch primer on mine and then two coats of the red.
Dries reasonable quick.
Gerard Offline
#15 Posted : Sunday, 29 May 2016 11:47:25 PM(UTC)
Gerard
Finished the badges for my car. Tried the different methods mentioned previously, but couldn't get a consistent finish doing them using those ways.
Tried using an airbrush and this worked well.
I used a combination of masking tape and vaseline for the masking, using the masking tape on any "easy to get at" areas on the GTS and the 5 litre badges and then painting vaseline on any other areas that don't need paint with a small art brush and tooth pick. After spraying them left them for a day and then removed the overspray with a plastic stick (with some small right angle cut outs on it) to scrape the paint/grease off. A cotton bud with some thinners on it tidied up areas missed with the tape or vaseline. Applied the black to the flags on the 5 litre badge with a toothpick.
Also did the taillights this way as well, but used masking tape only on the boot moulding.
Used Tamiya XF-7 for the GTS badges - Tamiya X-27 for the taillights boot moulding.
https://drive.google.com...MWlhYWtDaaFA0R3laZmhURXM
https://drive.google.com...MWlhYWtDaSzRwdGFyNkZoY28
https://drive.google.com...MWlhYWtDaZHJDMXZGclR1OVE
#16 Posted : Monday, 30 May 2016 10:41:49 AM(UTC)
You'd have to thin out the model paint allot to get it to drip off a tooth pick properly.
Looks good.
Did you use X-27 enamel or X-27 acrylic on the rear trim?
For my rear trim I'm going to put four strips of masking tape over the areas where the red paint actually goes and then air brush liquid latex masking film over the whole thing, then quickly remove the masking tape before the liquid mask sets. This will leave latex on the areas I dont want painted red. Then air brush X-27 enamel over the whole lot. After the paint has dried the latex peels away easily.
A bit of d!cking around but it worked well in trial with an old trim I have here.
Gerard Offline
#17 Posted : Monday, 30 May 2016 5:34:36 PM(UTC)
Gerard
The X-27 was the acrylic. I found this paint tended to build up in the airbrush nozzle when spraying the larger areas on the boot piece, this didn't happen with the XF-7 - but only spraying small areas with that paint . Forgot to mention that the white and blue on the flags of the 5 litre badges is "Testors" brand spray can enamel (numbers 1245 - gloss white and 1211 - gloss blue. This is old paint, not sure if this brand is still around) The blue was a reasonable match for the blue on the glove box emblem which I used as I had nothing else to match it to. I sprayed these colours into the air brush cup (can't remember if I thinned them though)
The latex method sounds good, would like to have tried that as well. Found this part of the restoration took a lot of trial and error = lots of time, but good experience and saves sending parts away, which is always a concern
Silverfox Offline
#18 Posted : Saturday, 9 July 2016 5:03:26 PM(UTC)
Silverfox
Thanks for the info Wayne and others. I have a few little jobs coming up and this info will be handy. Wayne which distributor did you use and did the mix it there for you or have to get it it? Cheers Nick.
#19 Posted : Saturday, 9 July 2016 7:54:03 PM(UTC)
Anyone who deals with the Valspar system of paints could do it for you.
I got it from Alltype Paints and they mixed a few different ones while I was there and eventually got it real close.
Alltype Paints
Address: 1750 Main N Rd, Salisbury Plain SA 5109
Phone: (08) 8281 6766
Email: [email protected]
Weekdays: 8:30am - 5:00pm
Saturday: 8:30am - 12:00pm
All they need to do is follow these details and the badge red will be the same every time in acrylic.
I'd like to get some mixed in enamel one day, the colour map number is S0517 and thats all they need to know to produce it in enamel I think.
Brand - Valspar
Sample size - 250ml
Sample price - $20
Note: I added 10 grams of L47 flattener but maybe 5 grams would have been better.
Edited by user Saturday, 9 July 2016 8:08:36 PM(UTC)  | Reason: Not specified
This page was generated in 0.114 seconds.
