HGV8 Offline
#1 Posted : Monday, 4 April 2016 9:41:20 PM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
I have noticed in recent years when I mention the word FX people get pedantic and correct me with the 48-215 carry on. I know FX is just a adopted name but technically I would of thought the correct name for this model would just be "Holden" or "the original Holden".
The 1950 ute was a 50-2106 so it how can the "correct name" be 48-215.
Wondering what others think?
Jim
j.williams
castellan Offline
#2 Posted : Tuesday, 5 April 2016 11:44:38 AM(UTC)
castellan
Jim
It is the original Holden as we mainly know it but Holden made other cars before this.
So it's a 48-215 series or even a 50-2106 for the ute in truth.
But this is just the model code and as all types have one so it's a bit weird to call it this as who calls a HR Premier sedan a HR-235 or a 66-HR235 or a 67-HR235 it is correct but as such being not the original, one has to mark it a model type.
The original Falcon GT-HO is not called a Phase one is it, as it's just a GT-HO.
The FX is best known way of pointing out what it is and most people know what you are on about or maybe truly it's called the "original Holden F series model" or a F-X more so than an FX.
No one could reject that's it's not an F series, could they.
Even tho the XW GT-HO is just that, there is another different one to the original Windsor powered one as there is the Cleveland powered XW GT-HO with only a 351 Cleveland GT engine in it, but then there is the XW GT-HO Phase 2, with much more difference to the others.
So then there is a XW GT-HO is one beast.
Then the XW GT-HO Cleveland.
Then the XW GT-HO Phase 2, to be correct.
#3 Posted : Tuesday, 5 April 2016 2:37:44 PM(UTC)
I'm not sure there is a correct answer, Dr Terry will be the best guide here I suspect. As far as i'm aware though, prior to their being different trim levels there was only the one car - the Holden, no need to call it FX or 48-215, just like castellan states for the GT-HO (no PhaseI). Call it GT-HO and it stands alone, just like the '48 Holden. Not sure what you do once the Business sedan and the ute comes along though!
Castellan is right, names and models can get confusing, and terms becoming common language doesn't help. Most GMH special Holden and Toranas are based upon lesser models and the naming is all over the place:
5.0L SL/R gets called SLR5000 (originally special package XU2) but 5.0L hatchback version is SS 5.0L.
The LH Homologation SLR5000 for GroupC gets known by its engine option code of L34.
The LX Homologation vehicle gets known by its special vehicle code of A9X (which is applied to XU2/SLR5000 but when applied to SS it has to be SS+L31).
However when the special vehicle package A9K is applied to HZ Kingswood SL sedan/wagon it isn't known as the A9K - it just gets called Kingswood.
Same with HQ SS, it is essentially a standalone thing just like A9X or XU1 but it doesn't get called XV2 but HQ SS.
HQ and HJ XX7/XU3 get called HQ or HJ Sandman, but they aren't all equal. There is Belmont Sandman, Holden Sandman and Kingswood Sandman. However come HX/HZ they are intentionally a unique vehicle like HQ SS or HQ GTS sedan.
Torana 4cyl in LH and half of LX are Toranas they just have the odd situation where the 4cyl is a U size and the 6/8cyl are a V size (whereas in Holden and Statesman they are the same W size). Yet come mid LX and there are no longer 4cyl Toranas, but we have Torana (V coded) and Holden Sunbird (U coded). And then UC changes that up where in many cases Torana is no longer a model/group of its own but an option pack on a Sunbird model. Confusing much!
Then comes Commodore with all the different option packages based upon lesser models.
I think its best to just say that marketing created the confusion - if Engineering was left to their own devices it would have been far more logical. But what would there be left to argue about?
#4 Posted : Tuesday, 5 April 2016 5:12:06 PM(UTC)
The original Holden was not given a model designation, just a year introduction. So all "FX" sedans are 48 model, utes were introduced in 1950 so became a 50 model. No different to a 57 Chev.
As we did not make a new model each year a model code was devised for the FJ on.
This is a number to letter code
0 = A
9 = B
8 = C
7 = D
6 = E
5 = F
4 = G
3 = H
2 = J
1 = K
So a 48 Holden is NOT an F series as F is 5, so an FJ = 52 E series is 1960s.
A 48 Holden would be GC.
back in the day though they were know by year of manufacture, so all the ads in the 50s have 48 Holden, 49 Holden, 50 Holden etc then FJ Holden.
The term FX seems to turn up around the mid 70s, and is derived from the "F series myth" and the X is unkown.
Technically it is a 48 Holden, the 215 is the model code. I would not call my wife's car a VT X69, but technically I could.
Mind you it is becoming more 'fashionable" to use option and model codes, HQ XV2 instead of HQ SS, HQ XV4 instead of HQ GTS/4, HQ XW8 instead of HQ GTS 350 sedan.
Warren
Edited by user Tuesday, 5 April 2016 5:35:49 PM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, 5 April 2016 6:23:38 PM(UTC)
I think that it's much simpler than any of that.
When the Holden car was first introduced there was only one version of one body style which was just known as the 'Holden'. When the Ute came along it was simply called the "Holden Ute'. Nobody used the codes 48/215 or 50/2106 back in those days. As the years went by, each year's production batch was known by its year of build. The used car trade would differentiate say a 52 model from a 48 model, because it was so much younger, even though it looked identical. Their respective resale values differed enormously. It was easy with the Holden because the chassis number was prefixed with the year of build.
Virtually every car on the Aussie market, especially back in those days, was known by its 'year model', not its model code.
When the 'new look' (FJ) model first appeared, the term FJ was not well known by the public. The two Holden series were then known as early models (FX) & new look models (FJ).
When the FE arrived, the 'F' series thing was gaining traction. OK then, if the FE was an FE & the new look model was the FJ, what do you call the early girls ? F what ? The used car trade quickly dropped the 1948, 1950 or 1952 thing. In typical Aussie style it was gradually simplified to a system where any early Holden with the vertical bar style grille got called the FX series & it has now been so for decades.
Exactly when or who started it is another huge debate for another day.
The 48 seems a little odd though, because most GM cars worldwide get released late in the year before their year model name. For example the 57 Chev was released in Sept 1956, the 65 Chev was released in late 1964 & so on. Most US cars (of all makes) still use this system today.
Either GM-H wasn't using the GM convention or the '48' model was running very late in it's development.
I have no problem calling all pre-FJ Holdens by the FX tag, but I do have a problems with purists who say it's somehow 'incorrect'.
Edited by user Tuesday, 5 April 2016 9:41:24 PM(UTC)  | Reason: Spelling
HGV8 Offline
#6 Posted : Tuesday, 5 April 2016 6:54:18 PM(UTC)
HGV8
Thanks for the reply's.
You guys make a lot more sense the crazy theories and silly arguments I have witnessed.
I will continue to call the 48 model the FX despite the abuse I get from some.
Calling it a 48-215 seems to clinical a name.
When we had a FX in the late 1960's, they were known as the FX.
If you were to call it a 48-215 people would of thought you were going mad.
The earliest advertisement using the FX name I have been able to find was by using the Government digital archive (TROVE) and is dated the 12th of June 1965 in the Canberra Times.
j.williams
detective Offline
#7 Posted : Tuesday, 5 April 2016 8:28:27 PM(UTC)
detective
...Look no further than the factory produced shop manuals...the first series was simply called a Holden, with the next (and on the manual cover) calling it the Holden "FJ" Series...
...These manuals came into existence at the outset of each series, and the models within were just an extrapolation of that series.
...The term "FX" has been around since at least Saturday August 8 1959, when Mentone Motors advertised a 1953 air-ride sedan in the Age classifieds... THE LAST OF THESE CARS WERE WELL UNDER 6 YEARS OLD !!
...The term "48-215" was first noted by a motoring journalist in 1962 who called ALL the first Holdens (utes and sedans) a "48-215 model".....just plain wrong.
...By the early 1970's motoring journalists and the Holden restorer snobs eventually decided THEY know best, and bequeathed that first Holden car a 48-215.....a term it was plainly never known by !
Edited by user Tuesday, 5 April 2016 8:53:27 PM(UTC)  | Reason: Not specified
 1 user thanked detective for this useful post.
Dr Terry on 5/04/2016(UTC)
#8 Posted : Tuesday, 5 April 2016 9:13:06 PM(UTC)
I believe several people, more learned than me, have tracked the term FX (in published print) back to the late 50s, in classified adverts etc. One of the reasons was that they used to charge classified adds by the character or line (or whatever). So the aim of a clever advertiser was to economise on space. The term FX was 'cheaper' or more efficient than things like 48/215, 1951 or even 'early Holden sedan'.
AFIAK somebody even found an early girl listed in a 1958/59 motor racing program, as an FX.
By the the late 60s/early 70s the term FX was used in spare parts catalogues in the car trade & was well accepted.
As I said earlier, there is nothing wrong with collectively naming all pre-FJ Holdens as FX.
IMHO it sounds like a generation X (or Y) conspiracy.
Edited by user Wednesday, 6 April 2016 8:25:47 AM(UTC)  | Reason: Spelling
castellan Offline
#9 Posted : Wednesday, 6 April 2016 11:28:37 AM(UTC)
castellan
0 = A
9 = B
8 = C
7 = D
6 = E
5 = F
4 = G
3 = H
2 = J
1 = K
Warren
That's true, it could be a GC but did Holden ever call the cars before this car a G code ? or was this list code only made up from the 50's.
castellan Offline
#10 Posted : Wednesday, 6 April 2016 11:46:25 AM(UTC)
castellan
Motor bikes are the same all over the world and Sep is the start of year date.
Now we have 2 dates on Jap cars as well the build date and the compliance date in Australia I think they are called, my build date is May 2015 and the Aus compliance is Aug 2015.
#11 Posted : Wednesday, 6 April 2016 1:45:22 PM(UTC)
Yeah, I think the Sept release/MY date thing is now becoming very commonplace worldwide.
On the subject of Aussie compliance plates, the time gap between the build date & the compliance date can vary markedly.
On Aust. built cars there is no issue; the 2 dates are usually the same, because they are built & 'complied' in the one factory.
Imported cars are a different 'kettle of fish'. The Aussie compliance plate is fitted by the local importer/distributor on the day it leaves the wharf or bond storage facility. With fast moving cars (Hyundai/Subaru/Toyota etc.) the time delay is often only one month, allowing for shipping schedules. Slow selling cars however can have a much bigger time gap.
I've seen things like mid-80s Alfa Romeos & top end Hondas & Mazdas where they were built in say 1986 & then complied in 1988. That's a lot of down time. Does that make the car an 86, or an 88 'model' ? Many of these cars had no build date mentioned on their tags.
How they 'date' a car in the used car trade has also varied over the years. Way back before compliance plates were introduced (Jan 1970) cars were 'dated' by one of two means. If the build date was known, which quite often wasn't, they would quote (or guess) that date. More commonly they would quote the year of first registration, which was far easier to ascertain. This latter method also often gave the car a handy 'decrease' in age. A car built in in say early 1967 could've sat in dealer's storage for many months & then got registered in say mid-1969 & many would quote the car as being a 1969 model (unless it was a well known model) & get away with it.
Compliance plates put an end to that, or so they thought. Now the used car trade used the compliance plate date, not the build date, because again the earlier compliance date could 'enhance' the car's resale value.
I'm not sure if it's now law or not, but I recently noticed at the car auctions, they would quote both the build & compliance dates for each & every car. You would hear the auctioneer quote a car as being an 06 build, 07 complied vehicle, or similar.
#12 Posted : Wednesday, 6 April 2016 2:45:02 PM(UTC)
The '68 Chevrolet and '68 Pontiac that GMH assembled and sold here is a corker for this sort of thing. GMH assembled them from CKD kits as required. IIRC the last of them was finally assembled around 1970. So whilst the driveline might have been built way back in 1967 and came over in the mechanical pack, the body wasn't assembled until say 1970 when it was painted, trimmed and then the vehicle assembled. All parts were still new when it was assembled. So is it still a 1968 Chevrolet Impala? You essentially had the situation where you'd say in 1970 - I just bought a new car! Cool, what is it? A 1968 Chevy. Didn't you just say it was new?
I've also seen a few other corkers with GMH ID plates. Acacia Ridge fitted the BODY and VIN tags prior to paint in 1978. Which meant they had to stamp the VIN plate and attach it to the body in the body plant before it was painted so it was a predictive system unlike Pagewood where the VIN tag went on in the assembly plant. So a HZ might get the VIN 8N70THH459578Z, where the first H means 1978 model (1/9/77 to 31/8/78) . However a slight delay saw the van completed on 1st September and the compliance plate attached says 9/78. So you have a 1978 model VIN plate and a 1979 model compliance - this becomes especially significant if an ADR change happened at that boundary.
The other place you see something similar happen is on 1970-1971 HG vans. Pagewood and Dandenong didn't build these, but only assembled them. The bodies were built and painted at Elizabeth, and got Elizabeth BODY and ADR tags plus an Elizabeth chassis number on the firewall. The bodies were shipped by train to the assembly plants. It is rare, but possible for one to be complianced 7/70 or 8/70 but get delayed and not be assembled until September or even October 1970. The VIN plate from Pagewood or Dandenong doesn't show the year in this case, but if you went to buy one in say December 1970 - January 1971 (which wouldn't be unusual to get an October build out of plant stock) and you were delivered a 7/70 complianced van you'd be like "the damn thing is near to months old - I want a new one" although it was only 2-3 months old.
Also note that my HJ Premier is complianced 12/74, VIN is consistent for 12/74, ordered 10/74 but not completed until late February 1975. There are a few LS's with similar mechanical options with the same delay. We think they all were held up for some reason, maybe the LSD or U17 dash or something. GMH appears to have purposely complianced the cars 1974, possibly even completed them bar the missing part(s). The reason? AHJ changed to BHJ on 1/1/75 - they'd have to have gone back and changed the tank, the evap stuff, added the vapour lines, added the canister, changed the carby and other stuff if they left them to be complianced in 1/75 or 2/75 which is what normally would have happened at Pagewood - the cars would go through the body plant, and wait as sealed up units then when all the bits were there they'd be assembled and get a compliance plate for the date of assembly.
#13 Posted : Wednesday, 6 April 2016 5:54:32 PM(UTC)
I think that a CKD Chev of any model, that was painted, trimmed & assembled in Australia in 1970 would need a compliance plate. You would get away with doing it as late as 12/69 but not at any time in 1970.
Your example of the 8/78 built HZ & then complianced in 9/78, is still a 1978 model car in anybody's language except for GM model year coding.
I remember seeing an LX Torana which had its chassis no. altered by the factory. It was built in Jan-78 & was originally stamped with a CLX prefix. By its day of compliance which must've been during the first few days of Feb-78, it was altered to DLX, by putting a slash thru the C & adding a D in front of it. It was very neatly done & obviously factory. It was done because there were a few new ADRs for Feb-78 at DLX.
It is interesting to see some of these cars that were held up awaiting parts & seeing how long they sat at the factory. They must've taken up a lot of otherwise valuable space at the assembly plants.
Another place you see disparities in compliance dates is with so-called 'Grey Imports' (the bane of the auto parts industry). We often see mid-90s cars with compliance plates dated as late as 2010 or later, due to the method of compliance. This is another case where the build date & compliance date are not even vaguely related.
#14 Posted : Wednesday, 6 April 2016 6:40:02 PM(UTC)
Possibly Terry, they may have semi-completed them in 1969 and sold them in 1970.
The HZ is a 1978 HZ as you say, but the point is no-one can categorically state that all 1979 model year HZ's have a J in the VIN - examples like this always break the mould.
#15 Posted : Wednesday, 6 April 2016 6:43:35 PM(UTC)
The Mentone Motors ad is interesting, as they also have a grey '51 sedan, a grey '52 sedan and a '52 utility.
The others are by year or by year and model ie they have a 1956 F.J., a '55 Special and a '58 F.E.
So the save letters just cannot be the answer as they waste letters on so many other advertisements within the same advertisement.
I guess you are always going to have those who say that Holden never called it an FX and those who will say it is the accepted identification. For a long time the clubs that looked after these models were the FX FJ clubs. Have they changed to 48, 50 and FJ Clubs?
Is a VG ute a VN ute? Some say yes some say no.
The same goes for V2 Monaro, are they VX in series I and VY for series II and III? Some say no but some parts have VX coupe on them.
Warren
#16 Posted : Wednesday, 6 April 2016 7:28:46 PM(UTC)
The last ones are easy I think Warren, VG isn't a VN and V2 is not a VX or a VY. Just as a VU isn't a VX. They can't really be, but common parts are shared. If some common parts make them the same then stretching it further a VK must be a WB (or vice versa). And even closer to the mark a Lexcen must be a VP or whatever it parallels with, or BT-50 is a Ranger or vice versa. When I buy parts for my Mrs' Lexus RX350 the common parts with a Kluger come in Toyota boxes but the RX350 and the Kluger have very different model designations regardless of being a different manufacturer on the surface.
Just had a thought, is the VX as mentioned on parts showing VX coupe the lux level designation? Meaning CV8 coupe as opposed to CV6 coupe? Are the parts in question common to V2, V2II and V2III? Reason I ask is if you are going to call a V2 a VX then a V2II has to be a VY and a V2III has to be a VYII doesn't it?
Edited by user Wednesday, 6 April 2016 7:31:10 PM(UTC)  | Reason: Not specified
#17 Posted : Wednesday, 6 April 2016 10:04:26 PM(UTC)
Some of this is a bit nit-picking. For all intents & purposes a VG is a VN & a VU is a VX. They even share the same parts catalogue.
The same can be said of the V2I, V2II & V2III, they share the same parts catalogue as VXII, VYI & VYII respectively. Holden don't do this with the various Statesman & Caprice models in those years. There are probably too many differences, so separate catalogues were warranted.
Various models of Lexus RX & Kluger do actually share the same model code, the early ones for example are all MCU28. The Wide Body Camry V6 & Lexus ES300 of the late 90s are both MCV20 models.
Comparing a Ford ranger to a Mazda BT-50 is a bit like the 323 vs Laser thing. They had different engine & equipment options & there was just too much interior & exterior differences for them to be called the 'same' car. A bit like the current Colorado vs Isuzu D-Max.
I think the Toyota Lexcen can be considered a VN-VS Commodore, apart from very minor badge & trim differences they were virtually identical. The public wasn't fooled with that one. Not as bad a the XFN Nissan Ute though, eh ?
#18 Posted : Thursday, 7 April 2016 7:18:39 AM(UTC)
Some of that I agree with Terry, but you'll never convince me a V2 is a VX or VY, nor a VG or VQ is a VN. I have the parts catalogues for VN, VP, VG and VQ and those are all different catalogues. GMH made them a different series thus they are a different series. If we are going to lump VG with VN because they look very much alike then we might as well start calling LX Torana LH.
Even though Lexcens are Commodore based i'd still not let them be entered in Commodore judging classes, but the Lexcan would be accepted at Toyota judging. The 2011 RX350 we have shares a lot with a Kluger, but afaik it doesn't share a model code yet common parts come in Toyota boxes. The PX Ranger and the equivalent BT-50 are very much alike - they look different, share lots of common parts and common assembly locations but are different vehicles as you say - however I reckon these two are similar in amount of common parts that a VN and a VG share, and probably very much more in common between them than a VY and a V2II (although the reverse applies with VZ where any VZ probably has less in common with a VZ CV8 than any V2 has with the Commodore stablemate).
detective Offline
#19 Posted : Thursday, 7 April 2016 3:12:39 PM(UTC)
detective
Warren
...quite literally the term "FX" was reserved strictly for the 1953 "Air- Ride" (Old Look New Suspension) 48 series Holden.
This term was well understood by the various car dealers, whereby the buying public weren't that sophisticated in their knowledge of the mechanical attributes of this smooth riding, new suspension model within the series. It was as if the buyer was being introduced to a newer style of car...it was considered THAT big a change...(even if it's appearance hadn't changed).
...It is interesting to note that FJ Holden body number 4 has recently surfaced with its body production date indicating an August 1953 build (ACC 8)...around the same time this term "FX" appeared.....??
Edited by user Thursday, 7 April 2016 7:00:35 PM(UTC)  | Reason: Not specified
castellan Offline
#20 Posted: : Thursday, 7 April 2016 3:48:13 PM(UTC)
castellan
I have Spark plugs catalogue with 7963 champion plug with plug gap 1.3mm are the same on the Crewman 5.7L V8 from 8/03 to 7/04 but then a new plug 9204 with gap 1.1mm from 11/04 to 1/06
9204 is the plug that started with the series 2 VY with new ADR laws in 8/03
What was going on between 8/04 and 10/04 with the crewman ?
Guest (7)
This page was generated in 0.128 seconds.
