Hk186p Offline
#1 Posted : Saturday, 30 April 2016 9:58:12 PM(UTC)
Hk186p
Hk Brake Booster Brkt all the same ? for Hk Ht Hg bought one of a Hg wagon trying to convert my Hk to disc brakes one Hole isn't in the firewall the fixed Stud upper Hole not there any help appreciated do I just drill a new hole or buy a Hk specific Bracket.
gm5735 Offline
#2 Posted : Sunday, 1 May 2016 10:55:04 AM(UTC)
gm5735
For the power assist disc brake setup there are two main arrangements. The first, used on early HK, has the pushrod connected to the brake pedal on a different axis to the vacuum booster centre axis. To adapt the pedal pushrod to the booster there is a relay lever, and pivot located in the booster bracket. I believe this was changed about mid 1968 to the same arrangement seen on all HT and HG, where the pedal pushrod is aligned with the centreline of the booster.
I think you need to have the booster relief "dent" in the right hand inner fender of your subframe if you want to use the direct acting booster arrangement.
Hk186p Offline
#3 Posted : Sunday, 1 May 2016 1:03:40 PM(UTC)
Hk186p
Yes I do have that but the hole is missing in the firewall as this car was an original drum brake model do i just drill the upper hole in the firewall.
#4 Posted : Monday, 2 May 2016 1:18:18 PM(UTC)
Yes, drill the firewall where required, there should be a small dent punched to locate the drilling position.
Hk186p Offline
#5 Posted : Monday, 2 May 2016 7:06:18 PM(UTC)
Hk186p
Thanks Dr Terry Have drilled it out.
