Joined: 29/04/2016(UTC) Posts: 31 ![Australia Australia]() Location: Suburbia
Hk Brake Booster Brkt all the same ? for Hk Ht Hg bought one of a Hg wagon trying to convert my Hk to disc brakes one Hole isn't in the firewall the fixed Stud upper Hole not there any help appreciated do I just drill a new hole or buy a Hk specific Bracket.
Joined: 16/04/2014(UTC) Views messages in topic : 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
For the power assist disc brake setup there are two main arrangements. The first, used on early HK, has the pushrod connected to the brake pedal on a different axis to the vacuum booster centre axis. To adapt the pedal pushrod to the booster there is a relay lever, and pivot located in the booster bracket. I believe this was changed about mid 1968 to the same arrangement seen on all HT and HG, where the pedal pushrod is aligned with the centreline of the booster. I think you need to have the booster relief "dent" in the right hand inner fender of your subframe if you want to use the direct acting booster arrangement.
Yes I do have that but the hole is missing in the firewall as this car was an original drum brake model do i just drill the upper hole in the firewall.
Yes, drill the firewall where required, there should be a small dent punched to locate the drilling position.
Dr Terry |
Thanks Dr Terry Have drilled it out.
