307chev Offline
#1 Posted : Thursday, 28 July 2016 8:42:29 AM(UTC)
307chev
Was thanked: 2 time(s) in 1 post(s)
Ok, so now I've had new rare spares rubber kit installed and the doors are a bit tighter to close.i take my mate for a test drive and he can't get out using the passenger internal door lever.it opens with the outside door lever fine.before I had the rubber kit installed it used open fine from the outside and only just open from the inside,I had a look but can't see what the problem is
Has anyone had this?any help is well appreciated
Oh the car is base model HK Monaro that I've put a 307 in 👍
Edited by user Thursday, 28 July 2016 8:46:29 AM(UTC)  | Reason: Not specified
griffo Offline
#2 Posted : Friday, 29 July 2016 8:19:51 PM(UTC)
griffo
Have you removed the door cards, are all the linkages are in place?...My experience is its mainly the drivers side..because of more wear and tear I guess...Its not to tight is it?...try adjusting the striker/bolt pin thingy.
Tour Director Offline
#3 Posted : Saturday, 30 July 2016 9:03:12 AM(UTC)
Tour Director
If you purchased a Rare Spares Rubber kit it may have had a spray can of "Rubber Magic" included. Follow the instructions and spray the door seals.
307chev Offline
#4 Posted : Saturday, 30 July 2016 10:25:34 AM(UTC)
307chev
It's the issue is a mechanical one,the door rubbers are fine.
I was hoping someone could tell me where the adjustment was ,maybe someone in the past has but sedan internals in my door
Seems like the internal door handle has a lot of travel before it does anything
Now that there's a bit of preloaded tention from the new rubbers it's not playing ball
Again it's nothing to do with the rubbers!
I look forward to the day when rares pump out HK shells👍 I want a race car!
gm5735 Offline
#5 Posted : Sunday, 31 July 2016 11:24:13 AM(UTC)
gm5735
As Griffo said, pull the door card off and see where the play is between the door lock remote control and the lock/snib assembly. There is an access hole at the inner upper rear of the door, where you can see the lock/snib assembly.
The only adjustment I'm aware of is at the lock striker plate on the B pillar, so it may be that you have to replace or rebush worn parts.
Edited by user Sunday, 31 July 2016 11:24:56 AM(UTC)  | Reason: Not specified
HGV8 Offline
#6 Posted : Sunday, 31 July 2016 5:31:37 PM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
I had the same problem with my drivers door.
Probably not the correct way to fix but I gave the long link from the handle back to the latch mechanism a slight bend...
Jim
j.williams
307chev Offline
#7 Posted : Monday, 1 August 2016 9:47:03 AM(UTC)
307chev
That occurred to me the other day,thanks for letting me know it worked for you
I will try this method
307chev Offline
#8 Posted : Sunday, 13 November 2016 6:42:22 PM(UTC)
307chev
door is fixed now, a small tab was in the wrong place in the mechanism
