Whippet Offline
#1 Posted : Thursday, 4 August 2016 10:41:21 AM(UTC)
Whippet
Needing to repair or fit a change over steering box and would welcome any comments and information and advice
Can the box be serviced/overhauled in the car or dose it have to be removed?
Looking at the rear spares parts available they list a repair steering box small parts kit is this the way to go ?? or alternatively would it be better just to fit a reconditioned change over complete assembly that they also list??
The problem with the steering box is a lot of free play (very sloppy) and adjustments to both the sector or the worm will not resolve this problem
#2 Posted : Thursday, 4 August 2016 12:50:04 PM(UTC)
If your steering box has gotten to the point where you've run out of adjustment on both adjusters, then the ball & nut assembly will be badly worn.
By the time you purchase the necessary new parts & re-bush the case & then re-assemble it, it would be better to just 'bite the bullet' & buy the Rare Spares exchange box.
They come with a new ball nut & shaft assembly included, which is quite expensive on its own.
Edited by user Thursday, 4 August 2016 12:51:58 PM(UTC)  | Reason: Spelling
Whippet Offline
#3 Posted : Friday, 5 August 2016 7:36:30 AM(UTC)
Whippet
Thank you DR Terry I was leaning towards the complete C/O unit .
Recommendations for a pitman arm puller that will not break??
Have read a few reviews and noted that some of the cheaper pullers break ?
bathurst72 Offline
#4 Posted : Friday, 5 August 2016 9:32:48 AM(UTC)
bathurst72
There is a better option than RS, from memory they did advertise on that evil site, but from what i can recall they modify the internals of the box and fit far better bearings than original. You can get yours reco, that way the date stamp will still match your car. They were a few more dollars, but far better. cheers
#5 Posted : Friday, 5 August 2016 9:55:23 AM(UTC)
That is a little bit cryptic. What "evil site" ?
The RS unit has a new ball nut assembly which has a slightly different ratio (15:1 instead of 16:1). That may be interpreted as being a 'modification'.
"Better bearings" is another one. What does that mean ?
edelbrock1 Offline
#6 Posted : Saturday, 6 August 2016 6:36:45 PM(UTC)
edelbrock1
Before you do anything, give this fella a quick call or email:
http://www.earlyholdenparts.com.au/services/
Top guy with great service. Will probably be able to rebuild your box cheaper and better than any change over item.
 1 user thanked edelbrock1 for this useful post.
Whippet on 7/08/2016(UTC)
