Bill Pine Offline
#1 Posted : Thursday, 29 September 2016 12:26:52 AM(UTC)
Bill Pine
Hi all,
I have a 186 engine and have pulled it down.
5 pistons have a part number 7429479, this number is on the inside of the piston.
Other nubers sinside arre 10-4, 10-5, 10-8 (i think)
The last piston has RAZ202Z 040 10P 01 QE, these numbers are on top of the piston.
Is someone able to tell me what pistons I am running i this engine, standard or over size?[img]null[/img]
Are the 5 pistons equivalent to a 202 piston 4 thou over?
Is anyone able to help?
Thanx,
Bill.
[img]null[/img]
Edited by user Thursday, 29 September 2016 12:43:56 AM(UTC)  | Reason: Add pictures
8D11PCH2 Offline
#2 Posted : Thursday, 29 September 2016 12:50:55 AM(UTC)
8D11PCH2
You have 5 Holden pistons and one Repco replacement. You can measure one of the Holden pistons and compare it to the .040 oversize Repco to ascertain if they are all the same size.
RAZ202Z 040 10P 01 QE.
The 040 = 40thou oversize
Bill Pine Offline
#3 Posted : Thursday, 29 September 2016 12:57:05 AM(UTC)
Bill Pine
Thank you 8D11PCH2,
I will check into it tomoro.
Bill.
#4 Posted : Thursday, 29 September 2016 6:07:44 AM(UTC)
202 uses the same bore size as a 186.
#5 Posted : Thursday, 29 September 2016 7:40:57 AM(UTC)
Originally Posted by: Bill Pine Go to Quoted Post
Hi all,
Are the 5 pistons equivalent to a 202 piston 40 thou over?
Thanx,
Bill.
The 202 & 186 share the same bore size, but the gudgeon pin height is different. This means that they are NOT interchangeable or "equivalent".
