Hk186p Offline
#1 Posted : Saturday, 5 November 2016 7:35:30 PM(UTC)
Hk186p
I have just bought new Rear Hk Wheel cylinders 9/16 bore and noticed the ends are different these are flat where as the old ones had a cut outs for the brake linings to fit into what do I do, take these out and fit the old ones or just let these new ends just butt up against the brake shoes??.
8D11PCH2 Offline
#2 Posted : Saturday, 5 November 2016 8:34:17 PM(UTC)
8D11PCH2
AFAIK the ones with the cutouts are for vehicles with drum brakes all round and the flat ended ones are for vehicles with disc front brakes. The rear wheel cylinder bore size to suit with drum front brakes is also bigger than 9/16".
The brake shoes are also different to match the different wheel cylinder pushrods.
Hk186p Offline
#3 Posted : Saturday, 5 November 2016 8:45:03 PM(UTC)
Hk186p
Thanks mate so what your saying is use the flat ends as they are is this correct??.
8D11PCH2 Offline
#4 Posted : Saturday, 5 November 2016 11:35:02 PM(UTC)
8D11PCH2
Do you have disc or drum brakes on the front?
