KBM Offline
#1 Posted : Monday, 30 October 2017 7:06:40 PM(UTC)
KBM
Anyone know of any exhaust outfit that can supply/ship a new exhaust system for a HK with a 307 chev column shift auto. I'm after an original looking setup from the "rams horn" flanges to the tail pipe. My car is a bit off finishing but i'd like to be able to start the already run in motor regularly to keep it lubed and make it easier to move around. Distance/cost makes it impossible to take car to a shop at this stage. Thanks, greg.
#2 Posted : Monday, 30 October 2017 7:25:09 PM(UTC)
Try Settlement Road Exhausts in Victoria.
These guys:
https://m.ebay.com.au/it...8cfffb3c88%257Ciid%253A4
I’d try and get a replica GTS327 system, these were option N10 on 307 other than Brougham.
Edited by user Monday, 30 October 2017 7:37:31 PM(UTC)  | Reason: Not specified
KBM Offline
#3 Posted : Monday, 30 October 2017 8:12:09 PM(UTC)
KBM
Thanks Byron, I've seen these guys advertised before for their mufflers. I'll give 'em a try and see if they do the whole system. I know the GTS327 system will make it breathe better but for my panelvan I'd prefer to keep with the single tailpipe out to the side as per original.
#4 Posted : Monday, 30 October 2017 8:28:16 PM(UTC)
Read the text in the auction, they say they do a full system.
KBM Offline
#5 Posted : Tuesday, 31 October 2017 6:15:22 AM(UTC)
KBM
the full system in the text is unfortunately for the 186S not the v8. Settlement Road Exhaust got straight back to me with a sorry no for the 307 exhaust. the search continues.
gmholdman Offline
#6 Posted : Tuesday, 31 October 2017 7:52:36 AM(UTC)
gmholdman
KBM, try Dwayne at HI-TECH EXHAUSTS 93125066. AL.
#7 Posted : Tuesday, 31 October 2017 7:55:32 AM(UTC)
At least they do the muffler and tailpipe as they are the same afaik.
KBM Offline
#8 Posted : Tuesday, 31 October 2017 1:08:54 PM(UTC)
KBM
Thanks gmholdman, I'll give him a ring. The muffler is the same Byron the only difference to tailpipe is on van and wagon it comes out the side instead of out the back to stop drawback of fumes through tailgate.
 1 user thanked KBM for this useful post.
Oldolden on 31/10/2017(UTC)
#9 Posted : Tuesday, 31 October 2017 3:18:36 PM(UTC)
That shouldn’t be hard to fabricate though. The only one I have is a mint system off a HK Brougham we pulled apart. The whole car was perfect. Simply modified the tailpipe for a coupe.
KBM Offline
#10 Posted : Tuesday, 31 October 2017 6:30:08 PM(UTC)
KBM
I've got an original small diameter tailpipe off a wagon so I can get the bends in the right place, especially at the end as it's not a straight cut. it looks like a slice across a 90 degree bend. as far as your mint system, seeing as it's in such good condition, it would be easy to unbolt it without any damage and get it copied. If rare spares or a reputable exhaust shop got a copy you'd make a lot of Hk restorers happy.
#11 Posted : Tuesday, 31 October 2017 8:05:58 PM(UTC)
It will be coming out eventually along with the 307, powerglide and 2.78 LSD banjo and all be stuck up on the pallet racking. I have located the original engine for the car too but it still hasn't changed my mind to upgrade it to 350, TH350 and 9" with hybrid 327 system (extractors, XY/XA GT resonators and the original back end). So when I get the time to pull it all out it could be copied then. Won't be probably until at least this time next year though.
KBM Offline
#12 Posted : Thursday, 2 November 2017 6:38:22 PM(UTC)
KBM
Hi-tech exhaust replied promptly with unfortunately another no. It's a shame you can't buy exhaust systems off the shelf for the old'uns but
"such is life"
gm5735 Offline
#13 Posted : Thursday, 2 November 2017 8:04:44 PM(UTC)
gm5735
I might be able to help with this one.
Please send me a PM.
KBM Offline
#14 Posted : Friday, 3 November 2017 6:43:25 AM(UTC)
KBM
Thanks gm5735, pm sent.
Silverfox Offline
#15 Posted : Tuesday, 7 November 2017 8:14:16 PM(UTC)
Silverfox
Hi Byron
Is there a reason for using XY/XA resonators? Better note or do they look the same as the 327 GTS resonators?
Nick.
Edited by user Tuesday, 7 November 2017 8:14:59 PM(UTC)  | Reason: Not specified
#16 Posted : Tuesday, 7 November 2017 8:55:21 PM(UTC)
Nick, heaps smaller and offset pipes to one side so will work with the HK crossmember and extractors. Ideally XW GT resonators would be better as they are half the size but they are almost extinct and the damn GT guys won’t let me have any!
#17 Posted : Friday, 10 November 2017 7:08:49 PM(UTC)
https://www.gumtree.com....n-wagon-panel/1051458026
These guys do van tailpipes. Also have 186S rear muffler.
Edited by user Friday, 10 November 2017 7:10:43 PM(UTC)  | Reason: Not specified
KBM Offline
#18 Posted : Saturday, 11 November 2017 7:01:34 AM(UTC)
KBM
Thanks Byron, I've already bought the muffler from settlement rd exhaust. I'll give these guy's a go for the tailpipe.
#19 Posted : Saturday, 11 November 2017 8:43:02 AM(UTC)
You might have to get the muffler and tailpipe in, and trailer it to a shop for the front part, which is only pipes. Do you have the heat shield and rubbers for the hangers and the hangers?
Rubbers:
http://www.ebay.com.au/i...44133:g:xTkAAOSwSHZWde6V
Hanger and bolt:
https://www.ebay.com.au/...55c4f:g:3dMAAOSw6YtZO23u
KBM Offline
#20 Posted : Saturday, 11 November 2017 10:15:49 AM(UTC)
KBM
heat shield and hangers are in place. gm5735 is looking into possible copy of front pipes for me, so hopefully i'll get all the pieces together and wont have to trailer the car to a shop.
Guest (7)
