Dave1970 Offline
#1 Posted : Sunday, 3 December 2017 7:06:30 AM(UTC)
Dave1970
Hi can any help workout these hg ute codes please
bo108gr
43007-s
131-12a
563-13134
#2 Posted : Sunday, 3 December 2017 8:20:23 AM(UTC)
Some of those numbers don't look correct. Maybe the plate is badly stamped, damaged, corroded or just dirty.
The first 5 digits should be something like 80180, which is for a 6-cyl Belmont ute. Other ute numbers are 80280, 80380 or 80480, for V8 Belmont, 6-cyl Kingswood & V8 Kingswood, respectively.
The G refers to HG series & R = right hand drive.
563-13134 is Dulux code for Glacier White, which is unusual in an HG, where the 'normal' white is Kashmir White. Although having said that Glacier was available on fleet order.
The the first part of the TRIM number (131-12A) isn't correct either. 131 belongs to a two-tone paint scheme in FJ. A Glacier White HG should be TRIM prefix 1821.
The second part of the TRIM number (12A) refers to the interior which for this code should be Red.
Dave1970 Offline
#3 Posted : Sunday, 3 December 2017 9:35:26 AM(UTC)
Dave1970
Ok thanks The photo not real good it’s hard to read my eyes ain’t that good either I’ll have another look but it’s supposed to be a factory v8 I’ll check again with you info thank you
Dave1970 Offline
#4 Posted : Sunday, 3 December 2017 10:01:27 AM(UTC)
Dave1970
It’s from what I can make out
80180gh8
Does that make sense
#5 Posted : Sunday, 3 December 2017 10:55:08 AM(UTC)
Pagewood HG plates are hard to read, the 8’s especially. It is probably built during HQ passenger production hence the HQ white.
Dave1970 Offline
#6 Posted : Sunday, 3 December 2017 11:31:21 AM(UTC)
Dave1970
Yeah ok the 80180g
From what I read 801 is a 6 cyl is that correct
#7 Posted : Sunday, 3 December 2017 11:52:34 AM(UTC)
0180 is 6cyl Belmont ute. If it was a V8 Belmont ute it'd be 0280.
Dave1970 Offline
#8 Posted : Sunday, 3 December 2017 12:48:37 PM(UTC)
Dave1970
Awesome thanks for all your help
#9 Posted : Sunday, 3 December 2017 6:44:46 PM(UTC)
Chassis number in firewall behind the engine should start AHG and end in an S.
Warren
