#1 Posted : Saturday, 15 May 2021 5:38:47 PM(UTC)
Can anyone confirm these or fill in the blanks:
VN Group A. Looks to be called option XV2. Is this the car or the engine? Hard to read on my 'fiche, is the torque of 411Nm at 4800rpm or 4000rpm? Is it 9.0:1 or 9.6:1?
VN SV5000. The parts catalogue doesn't list a different engine spec for this, but it does state the engine has a VE engine number prefix. Is this the same engine as the HSV enhanced engine, ie the 180kW? Was it only the SV5000 that used VE in VN? Or is it that 200kW engine? Was there an engine code for these 180kW and 200kW engines, or was it just an enhanced LB9?
justgm Offline
#2 Posted : Sunday, 16 May 2021 1:17:00 PM(UTC)
justgm
VN Group A service manual , Engine prefix VK, option code XV2, 9 -01 compression , 411@4800. SV 5000 has engine prefix VE ( as all 200kw VNs) 180kw is VU. Hope that helps , Mark.
#3 Posted : Sunday, 16 May 2021 3:03:00 PM(UTC)
Thanks for clarifying the figures, I thought it was 4800rpm but the 'fiche was smudged. Same with the 9.0:1. Is the XV2 the Group A VK engine, or is it the package?
I think there was only the SV5000 in VN with the 200kW VE engine, no other VN. It appears in VQ and VP in other cars but only in SV5000 in VN?
justgm Offline
#4 Posted : Sunday, 16 May 2021 4:04:06 PM(UTC)
justgm
VK Group A not EFI , do you mean VL Group A ? but that was only 180kw . XV2 is the option pack. only other VN I know of with 200kw engine was HSV T30 . Thanks Mark.
#5 Posted : Sunday, 16 May 2021 4:23:25 PM(UTC)
VK engine number prefix.
justgm Offline
#6 Posted : Sunday, 16 May 2021 4:32:06 PM(UTC)
justgm
Yes VK engine number prefix.
#7 Posted : Sunday, 16 May 2021 4:43:10 PM(UTC)
That’s what I meant, I was qualifying what I meant in the prior post, not asking a question. The question was is XV2 the VK prefix engine, or is it the GroupA package. This can get confusing, for example the 327 in HK was RPO code L34 but the GTS327 package was XT2 (which included L34). So just making sure. The fact that all the 165, 180 and 200kW engines seem to be LB9 was just double checking.
What I’m doing this for, is I’ve been compiling a list of all GMH V8 engines from start to end ie HT to VS. including all power/torque figures, compression, engine number prefixes and what they were used in. It goes with an article about the engine. Just missing a few figures. One I’d like to find is full figures for the Hurricane 253, hard to obtain though.
#8 Posted : Sunday, 16 May 2021 5:31:51 PM(UTC)
Byron, the figures I have for the Hurricane engine are:
10:1 compression, 260 bhp @ 6000 rpm & 260 ft/lb @ 3800.
PO number L33, engine no. prefix RD001, solid cam & QJet 4MV carby.
Dr terry
Smitty2 on 17/05/2021(UTC)
justgm Offline
#9 Posted : Monday, 17 May 2021 5:19:57 AM(UTC)
justgm
according to the Holden options book ( 1993) , XV2 means SS , in HQ , VH & VK , also XV2 means Group A SS in Vl & VN.
#10 Posted : Monday, 17 May 2021 10:34:47 AM(UTC)
correct.. it also covers the VK Grp A Blue Meanie
#11 Posted : Monday, 17 May 2021 11:37:44 AM(UTC)
Doesn't XV2 also apply to the VK HDT SS & SS Group 3 ?
AFAIK, the odd SS out is the HDT VL SS Group A, it was the A9L.
castellan Offline
#12 Posted : Monday, 17 May 2021 11:38:00 AM(UTC)
castellan
The blocks with VP Prefix is for VL SS Group A Walkinshaw and the Blocks with VK prefix are all the same type of 4 bolt mains Blocks, they have bigger diameter lifter bores as well.
The VE Prefix had a stock Block but was a red painted engine with a bigger Camshaft etc.
#13 Posted : Monday, 17 May 2021 12:20:35 PM(UTC)
yes.. as 'justgm' wrote above
but
the VK Blue Meanie is an oddball.... it is XV2 with A9L option
