AC Offline
#1 Posted : Sunday, 6 June 2021 11:53:11 PM(UTC)
AC
My HQ 202 ute that I am restoring has the hoses on the thermostat housing looped back. The inlet manifold looks to have a corroded connector so does not have hoses connected or coolant flowing through it. I have a new heater core. I have seen two way and three way taps for sale. Would a two way tap work or do it need to recreate the whole circuit along with a replacement manifold?
#2 Posted : Monday, 7 June 2021 8:00:21 AM(UTC)
HQ Holdens didn't get a heater tap, unless they had factory A/Cond.
You're better off replacing the inlet anyway, the engine will run much better especially in winter.
You could just run the 2 hoses from the thermo housing to the heater core if you wish, the heater will work fine.
Edited by user Monday, 7 June 2021 10:24:00 AM(UTC)  | Reason: Not specified
 2 users thanked Dr Terry for this useful post.
AC on 7/06/2021(UTC), Smitty2 on 7/06/2021(UTC)
AC Offline
#3 Posted : Monday, 7 June 2021 8:46:40 AM(UTC)
AC
Thanks Dr Terry. That makes it easy.
