holden05 Offline
#1 Posted : Saturday, 31 July 2021 3:07:32 PM(UTC)
holden05
Hi
Have replaced fuel pick in my wb ute and 40ltrs of new fuel
Started it up and let it run for 10mins
I’m not getting a reading on the guage
Guage was working before
#2 Posted : Saturday, 31 July 2021 4:30:27 PM(UTC)
Step 1 : Is your temperature gauge working ?? If it is go to step 2, if not get your gauge set checked by an instrument guy. There is a voltage regulator side it that supplies both gauges.
Step 2 : Get a resistor of around 20 to 25 ohms (cheap at Jaycar) & substitute it for the tank sender & try again. If the gauge now works, your sender is faulty.
Smitty2 on 31/07/2021(UTC)
holden05 Offline
#3 Posted : Saturday, 31 July 2021 5:49:00 PM(UTC)
holden05
So one end into the sensor wire and other end earthed?
KBM Offline
#4 Posted : Saturday, 31 July 2021 8:05:28 PM(UTC)
KBM
The gauge works on resistance so if it was working before you changed the sender the problem is more than likely resistance at the sender/pickup. remove the new pickup and clean the area it connects with the retaining ring and the retaining ring with steel wool. If the new pickup has been coated with anything that should clean it up. Also check the electrical fitting for corrosion.
#5 Posted : Saturday, 31 July 2021 8:05:48 PM(UTC)
Correct !!
holden05 Offline
#6 Posted : Saturday, 31 July 2021 10:48:45 PM(UTC)
holden05
Ok thanks
The sender unit im using is new from rare spares. Is it possible that it’s the wrong unit?
8D11PCH2 Offline
#7 Posted : Sunday, 1 August 2021 9:39:43 AM(UTC)
8D11PCH2
RSP part number SU1018N?
Edited by user Sunday, 1 August 2021 9:40:31 AM(UTC)  | Reason: Not specified
holden05 Offline
#8 Posted : Sunday, 1 August 2021 10:59:26 AM(UTC)
holden05
Yes, that’s the one
8D11PCH2 Offline
#9 Posted : Sunday, 1 August 2021 12:22:44 PM(UTC)
8D11PCH2
That is the correct sender unit for your WB.
If you still have the original sender you removed you could try connecting it up (out of the tank) to the sender wire and connect a ground wire from the sender unit frame direct to the battery. If your fuel gauge still works then you may have a poor ground to the new sender unit or the new sender is faulty.
I have heard of a number of these new repro sender units (to suit various models) being faulty straight out of the box.
holden05 Offline
#10 Posted : Sunday, 1 August 2021 12:54:25 PM(UTC)
holden05
Ok, I’ll give that a go. Thanks very much for your help, very
Informative
holden05 Offline
#11 Posted : Monday, 2 August 2021 1:45:28 PM(UTC)
holden05
Have contacted rare spares. They are saying that the wb never came out with a GTS dash
HK1837 Online
#12 Posted : Monday, 2 August 2021 1:52:19 PM(UTC)
They are sort of correct, there was no GTS in WB. WB had an option U17 sports dash that was available on commercials, but so did HZ where you could option the sports dash on most HZ unless it was already standard (GTS, Sandman and SL/E).
WB with U17 should use the same sender as HZ Sandman.
KBM Offline
#13 Posted : Monday, 2 August 2021 7:11:39 PM(UTC)
KBM
That shouldn't alter the fact the gauge doesn't work. Only altering resistance that I understand across the different gauge clusters for the fuel gauge would be air con.
#14 Posted : Monday, 2 August 2021 7:57:35 PM(UTC)
Sports dash or not, the sender was the same resistance from HJ to WB (excluding WB Statesman).
8D11PCH2 Offline
#15 Posted : Monday, 2 August 2021 9:17:01 PM(UTC)
8D11PCH2
Having A/C didn't alter the working resistance of the fuel gauge and sender unit.
8D11PCH2 Offline
#16 Posted : Monday, 2 August 2021 9:18:31 PM(UTC)
8D11PCH2
How did the test go with the original sender unit?
#17 Posted : Tuesday, 3 August 2021 1:13:06 AM(UTC)
Definitely came out with sports dash which is identical in every way to a GTS dash (except possibly the silver line around the edge of the facia).
holden05 Offline
#18 Posted : Tuesday, 3 August 2021 7:21:06 PM(UTC)
holden05
About 10 full and 120 empty
8D11PCH2 Offline
#19 Posted : Tuesday, 3 August 2021 7:46:10 PM(UTC)
8D11PCH2
So the test shows your fuel gauge is working.
The operating range for the thermal fuel gauge and sender unit is 10 ohms (full) and 70 ohms (empty) +/- an ohm or two for manufacturing tolerances.
holden05 Offline
#20 Posted : Friday, 6 August 2021 7:34:56 PM(UTC)
holden05
ill run a separate earth lead from the unit to the chassis this weekend to see if its an earth prob
The guy at rsp spares said there is no other sender option
The ute originally had the “basic” wb commercial dash in it but was fitted with a yellow needle woodgrain gts dash quite a few yrs ago. So he’s blaming the dash incompatibility
Edited by user Friday, 6 August 2021 7:36:25 PM(UTC)  | Reason: Not specified
Guest (10)
This page was generated in 0.119 seconds.
