Rfads Offline
#1 Posted : Wednesday, 1 September 2021 9:59:03 PM(UTC)
Rfads
Hi mate just wanted your opinion in the process of restoring my 69 HT it's a 161 factory Kashmir white and mirage blue with trim 1282 it has all it's original running gear I presume need someone to tell me if all the parts are in the the right time frame should I paint the car factory colours for resale if I decide to sell in the future and leave all the running gear as is if all part numbers line up thanks.
Rfads Offline
#2 Posted : Wednesday, 1 September 2021 10:21:17 PM(UTC)
Rfads
Hk187
#3 Posted : Thursday, 2 September 2021 8:40:02 AM(UTC)
If you want my personal opinion.
I'd paint it and trim it to look totally original.
Pull the entire drive train out and put it on a pallet, store it.
Fit front disc brakes including booster (if not already), upgrade to HQ-WB front rotors and calipers.
Redo all the suspension bushes, balljoints and steering. Don't lower it much, maybe 20mm. Buy some good quality oil shocks for it.
Get a stronger diff made up fitted with HQ-WB rear drums, either a 9" or a Borg Warner.
Find an injected VN-VS 5.0L, get a HT-HG sump, pickup and dipstick for it.
A TH350 or a Trimatic converted to TH pattern will fit without floor mods.
If the 5.0L you buy needs a rebuild your best bet is to find a manual pattern HT to WB/VK block and use that block for the rebuild then you can use a straight Trmiatic. This way you can keep the column shift to be even more original.
Or do something funky like convert the 3spd manual to a V8 3spd (input shaft and cover change) and use it behind the 5.0L.
Or do something less drastic and more sympathetic (and cheaper) and put a 253 in it and keep the original type gearbox and diff (just changed to V8 flavour, like a V8 banjo centre and tailshaft).
If you have more funds do what I did and buy a Rodtech front crossmember and brakes, complete with power steering rack. Allows you to run far cheaper engine bits (like not have to pay $800 for a HT-HG sump/pickup). Plus buy a vintage A/C kit and fit it up under the dash. Then run whatever engine you want keeping the donor vehicle's air and steer pumps.
Fair bit of work in the above but personally I reckon it increases the value of an original 161 car that easily covers any extra expenditure if you decide to sell it. If its going to be a cruiser or a car you take over any distances make sure you stick with a rear axle ratio around 3-3.25:1 with a box without overdrive, depending upon what height tyres you end up with. Best bet is to run 15" rims with tyres within 25mm diameter of the originals.
Rfads on 2/09/2021(UTC)
Rfads Offline
#4 Posted : Thursday, 2 September 2021 7:21:51 PM(UTC)
Rfads
Thanks for all that info I was thinking the same thing I'm keeping the original look column shift bench seat standard wheels it's going to just be a nice cruiser anything 253 upwards I'm looking at not looking at chopping up the gearbox hump to get a bigger box in or anything I'm yet to find a picture of the exact trim 1282-14G it's a early 69 build from what I no it must be a carry over trim from the HK if so would this make it a more rare combo
#5 Posted : Thursday, 2 September 2021 8:47:58 PM(UTC)
1282 is the exterior paint. 14G will be a standard HT trim, blue vinyl with a cloth insert. Won’t be early ‘69 as that was HK, unless it’s a pilot HT.
I’d just run a Holden V8 with a Trimatic or a 3spd manual. What box is in it now? So 253, 308 or 304. If you keep it carbied everything will be around for original fitment, just a few things get expensive like sump/pickup and the bit in the clutch mech you need to convert a clutch setup to suit V8. If you aren’t worried about originality you can use later rocker covers, timing case, HQ-HZ style radiator, aftermarket intake, generic carby, aftermarket air cleaner etc. If it’s a Powerglide I wouldn’t bother trying to convert it to a V8 Powerglide as that is not as easy as it sounds, best bet is finding a HQ-WB right hand shift V8 Trimatic. It will use the same gearbox crossmember as 6cyl Powerglide. Just needs a HG column and Trimatic linkage and HK-HG all synchro speedo cable (or HG Trimatic). If you want to have the auto lockdown you just need a switch somewhere on the throttle linkage and some wiring to the transmission and harness.
I wouldn’t run a banjo though, you’ll need to find a V8 one and they are stupidly overpriced. Invest in a Borg Warner or something stronger than a banjo.
#6 Posted : Thursday, 2 September 2021 8:49:15 PM(UTC)
Double post.
Edited by user Thursday, 2 September 2021 8:50:24 PM(UTC)  | Reason: Not specified
Rfads Offline
#7 Posted : Thursday, 2 September 2021 9:15:25 PM(UTC)
Rfads
Sorry what i meant was early build for the HT late 69 HK trim carry over.
Model HT80369
The numbers on the box are left side 7433725 right side 6-7433771 what box is this?
If I could upload pictures I would but can't seem to upload
#8 Posted : Friday, 3 September 2021 10:42:50 AM(UTC)
Why do you think HT would have HK carry over trim? 14G should just be standard HT Kingswood Twilight blue with a cloth insert. 14E is the standard all vinyl Twilight Blue on a HT Kingswood. For it to be HK trim it would be Light Teal or Jacana blue or Bayou blue or maybe another as there were a few different trim changes through the HK series.
Edited by user Friday, 3 September 2021 10:44:49 AM(UTC)  | Reason: Not specified
Rfads Offline
#9 Posted : Friday, 3 September 2021 12:02:39 PM(UTC)
Rfads
From what I could find and what I've been told it's bayou blue with cloth insert hence the reason I think they used up what ever they had left over on the early HT build would that be correct
#10 Posted : Friday, 3 September 2021 12:22:45 PM(UTC)
Bayou is early HK I think, can’t remember. There was lots of different trims used across HK. GMH would normally bring out new trim for a new series, and if they were using up unused trim it would normally end up slotted in during a series to get rid of it which they did do on HT and HG Belmont the if I recall correctly.
Rfads Offline
#11 Posted : Friday, 3 September 2021 12:33:53 PM(UTC)
Rfads
I guess that must be it then of you have a site or picture of the trim were I can see it that would be much appreciated by
Some more info if you can break it down for me I've got a fair idea but would love to hear it from someone with a world of knowledge like yourself.
Model- HT80369
Body-1638-a
Trim-1282-14g
Paint-568-10979
Top-568-11401
T
L1
