Dodge230 Offline
#1 Posted : Tuesday, 23 August 2022 5:47:20 AM(UTC)
Dodge230
Hi Guys
looking for help Please
Does the Outer window rubber weather strip on the front door of a HK Monaro fit the full length of the door or just up to the 1/4 window?.
I have a new rubber which only comes up the 1/4 window. Have checked with supplier and has said they are correct. But because the s/s trim sits on the rubber what happens on the last section without the rubber under it?
thanks
8D11PCH2 Offline
#2 Posted : Tuesday, 23 August 2022 6:29:38 AM(UTC)
8D11PCH2
Your supplier is correct. The belt weatherstrip does not go past the door division channel. The 1/4 window rubber seals up it's portion of the door.
I don't own a Monaro but I doubt the stainless belt mouldings will actually lap over onto the rubbers. They may virtually kiss the edges of them but I doubt they will sit over them.
Edited by user Tuesday, 23 August 2022 6:30:46 AM(UTC)  | Reason: Not specified
Dodge230 Offline
#3 Posted : Tuesday, 23 August 2022 8:26:52 PM(UTC)
Dodge230
Thanks, just didn't look right. Will have a go fitting the trim.
