#1 Posted : Monday, 17 April 2023 3:23:35 PM(UTC)
Does anybody on Fastlane know the PCD dimension for early Holden (FX/FJ) wheel rims.
gmholdman Offline
#2 Posted : Monday, 17 April 2023 6:35:35 PM(UTC)
gmholdman
Have a couple of drums here I will measure them up. AL. Dancing
gmholdman Offline
#3 Posted : Monday, 17 April 2023 7:00:16 PM(UTC)
gmholdman
Terry, 3 7/8” between stud centres x5.
Edited by user Monday, 17 April 2023 7:23:33 PM(UTC)  | Reason: Not specified
#4 Posted : Tuesday, 18 April 2023 6:39:14 AM(UTC)
That makes it 5 x 6 19/32 I think? Or is it the same as old Land Rover which is 5 x 6 1/2" which means the stud to stud measurement is actually 3 13/16 (just means you are out by 1/16" AL). Landrovers used a 5/8" stud IIRC.
gmholdman Offline
#5 Posted : Tuesday, 18 April 2023 2:32:17 PM(UTC)
gmholdman
Bent stud ?? or my old carpenters wooden 3’ rule with thick paint graduations ?? 😂😂😂. AL.
#6 Posted : Tuesday, 18 April 2023 5:34:34 PM(UTC)
Terry, I read on a Landrover forum that landrover, Morris Commercial and "FX"/FJ Holden are 5 on 6.5" PCD (165.1mm)
#7 Posted : Wednesday, 19 April 2023 7:24:09 AM(UTC)
Thanks Byron, that seems to back up AL's measurement.
Edited by user Wednesday, 19 April 2023 7:26:34 AM(UTC)  | Reason: Not specified
#8 Posted : Wednesday, 19 April 2023 7:18:32 PM(UTC)
this info ( I just checked ) is NOT in the original GMH 48/215 or FJ service/repair manuals I have
nor is there any info about replacing the wheels studs (front or rear)
... curious that!
#9 Posted : Thursday, 20 April 2023 7:47:19 AM(UTC)
... curious that!
Exactly & my reason for asking the question in the 1st place. I couldn't find it in any GMH literature & believe me I have a ton of it.
On the topic of wheel stud PCD, have you noticed that the FE to HG (& Torana) PCD was always quoted as 4.24 inches & not 4.25 (which is a more logical imperial 4 1/4 inches).
#10 Posted : Thursday, 20 April 2023 9:26:52 AM(UTC)
I had seen that too Terry and thought WTF? Its even in the Engineering Technical Specs: 5 stud 7/16", 20 UNF 2A thread, 4.24" PCD.
#11 Posted : Thursday, 20 April 2023 4:24:11 PM(UTC)
I remember a long time ago, an argument raging on the GMH-Torana site about this but
no recollection of the outcome as to the why.. why so
but I do remember a silly bit of trivia from that topic, HB Torana is exactly 4.000" Dancing
#12 Posted : Friday, 21 April 2023 7:36:31 AM(UTC)
Yeah, HB to TA 4-cyl Toranas were 4 stud @ 4.00" like a lot of other Pommy cars of the era. When I talk about Torana I often forget about the little Vauxhall ones.
#13 Posted : Friday, 21 April 2023 7:43:48 AM(UTC)
I was part of that discussion & yes it did "rage". Most thought it was a misprint, but my point was that was a lot of misprints in a lot of different manuals over several decades. Man, now that's a misprint.
Smitty2 on 21/04/2023(UTC)
#14 Posted : Tuesday, 8 August 2023 7:59:42 PM(UTC)
It came up again elsewhere on GMH-Torana Terry.
I still reckon it’s a perpetuated error. Otherwise it’s a crazy stud pattern like 4 31/128”.
Do you have any VH docs showing the 4cyl PCD?
Edited by user Tuesday, 8 August 2023 8:01:46 PM(UTC)  | Reason: Not specified
#15 Posted : Tuesday, 8 August 2023 9:37:16 PM(UTC)
VC, VH (and VK too) 4 cyl model steel wheels ... all 5.5 x 13" are the same part
number as on UC Torana if I recall this right from my days of checking GMP&A catalogues
first off prints (lots of people in house at GMH were asking this same question when VC came out)
Does that help?
Edited by user Tuesday, 8 August 2023 9:38:17 PM(UTC)  | Reason: Not specified
#16 Posted : Wednesday, 9 August 2023 6:14:58 AM(UTC)
I have no doubt the wheels are essentially the same. I was just wondering if they revisited the specs when changing the stud threads and specs to metric. I also thought 4cyl Commodore wheels didn’t have hubcap clips?
Smitty2 on 9/08/2023(UTC)
#17 Posted : Wednesday, 9 August 2023 1:04:04 PM(UTC)
my recollection, (I was given a * VH SL version to drive to Acacia Ridge on one work visit ) is they sorta had .. several bumps in the middle circle pressing of the wheel centre so
GMH fitted a horrid plastic hubcap to VC 4cyl Commodores ( though they fitted UC 6cyl Torries with steel wheels with a plastic hubcap and 4cyl Sunbirds a sort of shiny metal cover)
The base SL VC and VH 4 cylinder cars got a centre cap (retained by the wheel itself) again like the 4cyl Torana
*this thing.. manual 4 cyl with aircon was the only car I have driven in the country flat out WOT
never get caught speeding... up a hill with aircon on it would gradually lose speed, a down shift
was needed to go up a rise or hill on the Hume !
Edited by user Wednesday, 9 August 2023 1:06:55 PM(UTC)  | Reason: Not specified
#18 Posted : Wednesday, 9 August 2023 5:36:22 PM(UTC)
Like this I meant. I thought they were like LC-LJ GTR rims with no hubcap tabs.
Smitty2 on 11/08/2023(UTC)
#19 Posted : Thursday, 10 August 2023 11:36:13 AM(UTC)
I'm not sure about the hubcap nibs, but I believe that the Commodore rims have more offset than the Torana ones.
#20 Posted : Friday, 11 August 2023 9:13:32 AM(UTC)
thanks
thats what was the base vehicle version with the plastic wheel centre cap
this...is what I was referring to
Guest (14)
This page was generated in 0.065 seconds.
