Taztiger4 Offline
#1 Posted : Monday, 15 May 2023 8:59:22 PM(UTC)
Taztiger4
Any tricks or pitfalls ?
#2 Posted : Wednesday, 17 May 2023 7:41:55 AM(UTC)
A little more info might help.
Are you talking about the latch mechanism inside the door or the lock barrel ?
Taztiger4 on 17/05/2023(UTC)
Taztiger4 Offline
#3 Posted : Wednesday, 17 May 2023 9:28:46 PM(UTC)
Taztiger4
Apologies, I am talking about the actual lock barrel
KBM Offline
#4 Posted : Thursday, 18 May 2023 10:25:25 AM(UTC)
KBM
the barrels are fairly straightforward. there's a retaining clip at the back of the barrel that usually slides towards the inside of the door, there's a grab point on the clip. the barrel then pulls out. only thing to watch for is left and right as they're off set at the rear of the barrel so don't put them in upside down.
 1 user thanked KBM for this useful post.
Taztiger4 on 18/05/2023(UTC)
Taztiger4 Offline
#5 Posted : Thursday, 18 May 2023 9:22:55 PM(UTC)
Taztiger4
Thanks very much.
I have the 2 new barrels & they are identical !
Looks like the Z bracket held on by the 3 pronged clip can be moved 180deg to fit either door.
I am assuming the flat part of the key is at the top as it goes into the barrel ?
TIA
#6 Posted : Thursday, 18 May 2023 10:27:42 PM(UTC)
Yes, all my old holdens always had the flat/straight edge of the key upwards.
 1 user thanked Sandaro for this useful post.
Guest (6)
This page was generated in 0.083 seconds.
