Mav Offline
#1 Posted : Thursday, 18 May 2023 2:10:01 PM(UTC)
Mav
Will a hz banjo rear sway bar fit a Salisbury v8 10 bolt diff in a hz?
I have found a banjo diff with rear sway bar and want to fit it to my Salisbury diff.
justgm Offline
#2 Posted : Wednesday, 24 May 2023 5:54:27 AM(UTC)
justgm
6 cly bar is 9946483 and V8 bar is 9947541 , but could just be a diameter difference ?
#3 Posted : Wednesday, 24 May 2023 6:51:08 AM(UTC)
tape measure jobbie...
measure the distance between the brackets... if the banjo and Salisbury distances are the same
then the only other issue is the insulator as the V8 one is thicker
#4 Posted : Wednesday, 24 May 2023 7:20:50 AM(UTC)
What about a different shape (larger loop ?) because of the larger diff bulge ? I'm not sure, just asking.
#5 Posted : Wednesday, 24 May 2023 7:01:12 PM(UTC)
6cyl 1s 14mm. V8 is 16mm.
#6 Posted : Wednesday, 24 May 2023 9:00:37 PM(UTC)
Holden used the same shape bar on Commodores and also on WB I recall .. with both the small and large Salisbury diff cenrtres
which have rather different diff covers.. but still not 100% on this
Edited by user Wednesday, 24 May 2023 9:01:16 PM(UTC)  | Reason: Not specified
