Conoregan87 Offline
#1 Posted : Sunday, 28 May 2023 10:58:19 AM(UTC)
Conoregan87
Hi Gents,
The solenoids in the front doors on my HJ are on the way out.
See attached photo's - can you recommend replacement solenoids? Ideally something like-for-like that won't require modification to replace.
Regards,
Conor
Edited by user Sunday, 28 May 2023 11:01:09 AM(UTC)  | Reason: Not specified
#2 Posted : Sunday, 28 May 2023 2:01:13 PM(UTC)
Central locking on an HJ was very rare, usually only seen in late Statesman Caprices, yours may not be factory units.
I note that that your wire colours are blue & green. The factory wiring was black & dark green.
You could check out places like Jaycar, they sell universal fit door lock solenoids.
#3 Posted : Sunday, 28 May 2023 3:54:37 PM(UTC)
I don't think I ever saw central locking on HJ Terry? My memory said HZ and the solenoids were down low. They were attached by hex head screws not phillips head if my memory still works. Doesn't mean they didn't exist, I just never came across them. The only place in internal literature I can even find mention of them is in an early issue of the HX Features manual (12/75) where it says "power door locks are new for Statesman Caprice". That is gone from the August 1976 revision though. It is quite clear on the HX Caprice sales brochure though that electric door locks are included. Will go and see if I can find anything for HJ.
tidyVan Offline
#4 Posted : Monday, 29 May 2023 10:11:34 AM(UTC)
tidyVan
They look like an early Rhino type that I also have.
The current type look different.
https://www.rhinoco.com....tral-locking-slave-motor
Premier 350 Offline
#5 Posted : Wednesday, 31 May 2023 6:08:39 PM(UTC)
Premier 350
Given the sometimes close relations between GMH and GM North America, I wonder if GMH used a GM part from there?
Pure speculation on my part.
#6 Posted : Wednesday, 31 May 2023 6:27:59 PM(UTC)
Very well could be. The power window motors are. Hard to tell with later W size stuff though as they used 92xxxx part numbers for a lot of stuff even if it was imported. In HQ they tended to use the US part numbers.
8D11PCH2 Offline
#7 Posted : Friday, 2 June 2023 7:02:52 AM(UTC)
8D11PCH2
Agree, the one in the OP's HJ is an aftermarket central locking motor.
Edited by user Friday, 2 June 2023 7:03:32 AM(UTC)  | Reason: Not specified
tidyVan Offline
#8 Posted : Friday, 2 June 2023 9:26:32 PM(UTC)
tidyVan
Not an exact match, but close. Rhino brand.
Rhino lock
Rhino lock
I3arana Offline
#9 Posted : Tuesday, 3 February 2026 8:07:27 AM(UTC)
I3arana
[img]null[/img]
[img=https://app.box.com/s/9n5jt2ojce7g37cu2bs12ff1et4namax]1[/img]
[img=null]https://app.box.com/s/wi2rf4qdban64kyflgcrc70bbt66w2v5[/img]
[img=null]https://app.box.com/s/rzrnnyjqd6tpxn24eha0tis1b7fdqzxc[/img]
This is the original rhino system.very close to an aftermarket. I googled, apparently someone hass it up on e-flay
