Taztiger4 Offline
#1 Posted : Thursday, 29 June 2023 10:21:18 AM(UTC)
Taztiger4
Hi again :)
My 10/74 One Tonner has the inner door belts roughly screwed to top metal portion of Door card, is this correct ?
When I search for replacement I can see HQ appear to be different to HJ-WB, how / why would they be different ?
I ask as mine is a HJ but identifies as HQ regularly, for example my bonnet lacing rubber retainers have 3 holes (HQ) whereas HJ should have 2 !
Thanks again in advance
#2 Posted : Thursday, 29 June 2023 4:21:38 PM(UTC)
HQ front door belt strips are shorter that HJ-WB, because there is a small triangle spacer at the front corner of HQ doors.
What do you mean by "mine is a HJ but identifies as HQ regularly" ? The doors are either HQ or HJ, there is no crossover.
Taztiger4 on 29/06/2023(UTC)
Taztiger4 Offline
#3 Posted : Thursday, 29 June 2023 6:19:50 PM(UTC)
Taztiger4
Thankyou, I wasn't aware the doors were different, i will have a look & confirm what I have
HK-Q-Z5.0Lfan Offline
#4 Posted : Thursday, 29 June 2023 8:26:52 PM(UTC)
HK-Q-Z5.0Lfan
I presume as it has a commercial front, it looks like HQ
Bollicks Offline
#5 Posted : Saturday, 1 July 2023 11:44:16 AM(UTC)
Bollicks
Hi
I have a 79 HZ 1ton. My understanding is all 1tons have HQ panels and cabs (certainly in NZ)
The strips in mine are held in place with a form of stakeing, and the doors have the triangle insert on the front bottom corners of window frameing.
Ian
#6 Posted : Saturday, 1 July 2023 12:09:39 PM(UTC)
No they don’t. HJ have HJ cab, HX have HX cab and HZ have HZ cab. Most HJ to HZ continued with HQ design front sheetmetal but the cabs are still HJ, HX or HZ, they just have the style lines in the cowl to match the bonnet. They used the doors like any other HJ to HZ in the same Series.
HJ to HZ cab chassis were available as a Special Vehicle Package option code BO6 which had Premier front sheetmetal and door trims, plus a few other bits. The only way to get a 5.0L in HJ to HZ cab chassis was along with option BO6.
Taztiger4 Offline
#7 Posted : Saturday, 1 July 2023 4:05:46 PM(UTC)
Taztiger4
No, It doesnt have a commercial front.
Tags say HJ but as stated above my bonnet lacing rubber retainers have 3 holes (HQ) whereas HJ should have 2.
I cannot see a little triangle corner except at the very top front of the door frame
My existing door belts are 750mmm long
Edited by user Saturday, 1 July 2023 4:46:58 PM(UTC)  | Reason: Not specified
202tonner Offline
#8 Posted : Sunday, 2 July 2023 2:15:59 PM(UTC)
202tonner
I have a HJ and a HQ door on my tonner.
You have HJ doors. The door belts are 750mm long. For HQ doors they are around 715mm.
The door design was changed from HQ to HJ. The little triangular spacers were removed, the door frame was strengthened and the support for the window glass was changed. That causes the difference. The changes were all internal though, both HJ and HQ doors will fit your tonner.
The door belts were stapled on with heavy duty staples. These had the advantage of being flush with the door belt.
You can use rivets if you don't have a HD stapler but you need to place the rivets so the butt-end of the rivet doesn't hit the top of the door frame which isn't straight, it wobbles around a bit. Easiest would be to use the existing screws. Or you could rivet through the screw holes as I think the screws would stick out the same as rivets so the hole spacing should clear the door frame. Either works.
Good luck.
 1 user thanked 202tonner for this useful post.
Taztiger4 on 2/07/2023(UTC)
Taztiger4 Offline
#9 Posted : Sunday, 2 July 2023 4:35:34 PM(UTC)
Taztiger4
Good luck.
excellent, thankyou
Bloody supplier told me the exact opposite, they said people buy HQ belts & cut them down to size !
Good advice re rivets & mounting ,thanks again
