Taztiger4 Offline
#1 Posted : Sunday, 17 September 2023 11:27:53 AM(UTC)
Taztiger4
Hi again
Does it matter which way the hoses are connected at the thermostat & water pump & also enter the heater ?
See the photos below, both are totally different so I assume it doesn't matter ?
#2 Posted : Sunday, 17 September 2023 4:40:23 PM(UTC)
On HQ and HJ there is a three way tap to turn water off from the heater when not in use. HX on have two hose tap.
#3 Posted : Sunday, 17 September 2023 4:55:30 PM(UTC)
HQ without a/cond has no tap, the water in the heater flows all of the time.
Because you have an HX/HZ thermostat & water pump, you will need to eliminate the short by-pass hose which runs from the thermo housing to the water pump. It is effectively 'shorting out" the heater & you will be getting virtually no flow thru the heater & no heat as a result.
The 3-way tap only applies to HQ with factory a/cond & HJ with a/cond or forced air ventilation.
Taztiger4 Offline
#4 Posted : Sunday, 17 September 2023 5:30:58 PM(UTC)
Taztiger4
Thanks Warren, Mine & the 2 pics I shared dont have a tap al all.
I was going to use a 2 way on mine
Does it matter which way the hoses go ? and whilst on that, does it matter which hose the tap does go in ?
Taztiger4 Offline
#5 Posted : Sunday, 17 September 2023 5:34:31 PM(UTC)
Taztiger4
Thanks Dr Terry
So you are talking about the short hose in the pics I posted ?, how do I plumb the hoses without it ? or do I need to go to HQ water pump & single spigot thermostat ?
#6 Posted : Sunday, 17 September 2023 6:19:23 PM(UTC)
Originally Posted by: Taztiger4 Go to Quoted Post
Thanks Dr Terry
Pre-HX water pumps have been NLA for decades. There are 2 methods to block off the water hose.
You can buy 2 block- off caps (Mackay P/No. BC16) & cap off both fittings, eliminating the hose.
Another method is that some water pumps have one of the outlets is threaded & suppled with a block plug when new, so they can be fitted to HQ/HJ etc.
If your pump is threaded screw in a plug & refit the hose.
Taztiger4 on 17/09/2023(UTC)
Taztiger4 Offline
#7 Posted : Sunday, 17 September 2023 7:19:38 PM(UTC)
Taztiger4
Thanks Dr Terry
Cheers , so just remove that short pipe & use the 2 block- off caps ?
or block off the water pipe outlet with the block plug & use the single spigot thermostat housing ?
Edited by user Sunday, 17 September 2023 7:25:09 PM(UTC)  | Reason: Not specified
#8 Posted : Sunday, 17 September 2023 7:23:57 PM(UTC)
Yep.
PirLPe Offline
#9 Posted : Tuesday, 19 September 2023 6:07:58 PM(UTC)
PirLPe
Thanks Dr Terry
It's easier than I thought. Thank you.
Taztiger4 Offline
#10 Posted : Wednesday, 20 September 2023 10:50:18 PM(UTC)
Taztiger4
Is there actually any point to doing this with the 2 5/8 hoses from pump to thermostat ?, would be neater & easier to block all 4 ports with the BC16 blanking caps Dr Terry suggested
Edited by user Wednesday, 20 September 2023 10:51:01 PM(UTC)  | Reason: Not specified
