mauser Offline
#1 Posted : Friday, 15 December 2023 5:21:16 PM(UTC)
mauser
Hi,
Have a VR 304 with an engine number VU624xxx. Would that block be late enough to have been relieved for the stroker or how would I tell from the exterior?
Thanks,
Mauser
#2 Posted : Friday, 15 December 2023 5:50:43 PM(UTC)
Originally Posted by: mauser Go to Quoted Post
Hi,
Thanks,
Mauser
what is the cast date? look at the numbers on the top of the cam tiiming chain extension at the front
late cast 1994 dates most likely relieved if there is NO casting of a 5.0 on the outside
if its a 1992 or 1993 date, the answer def is not.
Edited by user Friday, 15 December 2023 5:51:45 PM(UTC)  | Reason: Not specified
#3 Posted : Friday, 15 December 2023 6:19:09 PM(UTC)
As above. It will say 5.0L if it’s the standard 304 or be blank if it has the reliefs to be built as a 304/5.0L or a 350/5.7L.
