tidyVan Offline
#1 Posted : Tuesday, 28 May 2024 5:13:22 PM(UTC)
tidyVan
There are two holes in the floor pan where the drivers left foot would rest.
What are they for?
They can be seen in the following videos, so I know they are a common thing.
Seen here:
https://youtu.be/wFy76FiL8QI?t=98
And here but harder to see:
https://youtu.be/yk40zP5OEcA?t=300
tidyVan Offline
#2 Posted : Wednesday, 29 May 2024 4:54:41 PM(UTC)
tidyVan
I'll answer this one myself in case a future person is wondering the same thing.
The holes are there in manufacturing and are usually filled with seam sealer or equivalent.
#3 Posted : Wednesday, 29 May 2024 6:01:53 PM(UTC)
ummm... not in my experience
GMH put a small bung or blanking plate over those (and others) on the Holden series floor pans
and
on Commodore went for a rubber grommet on all (as seen below)
tidyVan Offline
#4 Posted : Wednesday, 29 May 2024 7:10:19 PM(UTC)
tidyVan
This is the clearest image I've been able to find.
It's the two small holes on either side of the tunnel, not the large holes that would have blanking plates put over them.
Floor pan holes
Edited by user Wednesday, 29 May 2024 7:11:24 PM(UTC)  | Reason: Not specified
#5 Posted : Thursday, 30 May 2024 3:26:21 PM(UTC)
They used to punch those through those low point channels so when the bodies in white were sitting outside waiting to enter the body plant paint area water could run out. If you look at HK-HG they are there too. Not all body plants did it though from memory, I know Pagewood did. I think they also did double duty allowing the body dip to run out when the body was dipped.
#6 Posted : Saturday, 15 June 2024 10:55:29 AM(UTC)
Bare metal bodies went through a shower of hot water and phosphoric acid known as phosphating to etch and prep the metal. All of that had to drain out.
Then onto the drier, then they were dipped and that also had to drain out.
I think mine had 8 or more holes filled with black mastic.
