Fastlane
Holden Forums
Holden Technical Talk
H Series Full cable clutch pedal.
Doing a 308 conversion into an HQ. Want to go full cable clutch but don't want to pay the huge price for a genuine pedal. I am going to weld the hook onto a HQ ratrap pedal and shorten it as necessary. Does anyone have the exact measurements of the V8 hook and the total length of the pedal. Or alternatively how much shorter is the V8 pedal. Will be welded by an engineer. Thanks.
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
V8 WB pedal is the same length as all HQ to mid HZ. It is only 6cyl WB (and late HZ) that is longer.
Just buy a repro pedal. Cheaper than modifying one. In my experience most Engineers can't weld! |
Good. Only need the specs of the V8 hook then. Welder is an expert. Thanks.
Resto country don't supply the conversion kits any more. I am in need of the cable support bracket with the 2 pivot holes if anyone can help. Thanks
I think you only need that if you are running a 6cyl pedal. If using the lower hole you can use the HX or early HZ bracket. The top pivot hole only suits 6cyl. |
Fastlane
Holden Forums
