MelbHZ Offline
#1 Posted : Thursday, 28 November 2024 12:06:29 PM(UTC)
MelbHZ
I've got a '78 HZ sedan and every time I go to the service station to fill the tank I get a gush of fuel coming out the filler neck, before the tank is full.
I'm thinking the breather is blocked or something.
Can I pull the breather hose from the charcoal cannister and blow compressed air back towards the tank?
Or do I need to drop the tank and have a look?
Thanks in advance
#2 Posted : Friday, 29 November 2024 10:20:42 PM(UTC)
I have the same with my hq sedan if I hold the filler full throttle. I find I need to hold it 2 thirds on to avoid the gush issue
#3 Posted : Saturday, 30 November 2024 10:35:17 AM(UTC)
It's odd you are having the issue, as fuel pumps today are so slow compared to what they were like in the 70's and 80's. Are all the breather pipes setup right?
#4 Posted : Saturday, 30 November 2024 4:35:10 PM(UTC)
I assumed it was caused by the relatively horizontal alignment of the fill pipe
#5 Posted : Saturday, 30 November 2024 6:40:04 PM(UTC)
I agree, but they were fine in the 70’s and 90’s, I had HQ to HZ sedans and an LX as daily drivers for near 20 years. Unless modern fuel pumps work differently to back then, it must be a breather issue?
#6 Posted : Saturday, 30 November 2024 9:23:55 PM(UTC)
I have trouble filling my WB Ute too. Have to trickle fill the last 10 litres. I assumed it was a breather issue.
MelbHZ Offline
#7 Posted : Monday, 2 December 2024 10:22:21 AM(UTC)
MelbHZ
I'll have a look at the breather at see if it's blocked somewhere.
202tonner Offline
#8 Posted : Sunday, 8 February 2026 6:55:13 AM(UTC)
202tonner
Added for reference.
In tonners there is a breather pipe inside the tank at the top, marked in red in the image.
This pipe is brazed or soldered to the tank and over time will come loose and tilt down so it is resting at the bottom of the tank. End result: no breather.
Mine did this a few years back and soldering the pipe back into place at the top of the tank gave much better fuel pumping. It has done it again unfortunately because I did a crap soldering job and now I can't get a full tank.
Not sure what happens with sedans and other types, the pictures in the parts book aren't very clear, but it is something to look at if you are having trouble fueling up.
But even with the breather in place, like Sandaro, I can only hold the filler at 2 thirds or it gushes out.
 1 user thanked 202tonner for this useful post.
MelbHZ on 9/02/2026(UTC)
