Joined: 30/08/2023(UTC) Posts: 28 ![Australia Australia]() Location: Melbourne Thanks: 1 times
Hi all, anyone know where I could get a EGR valve gasket and the gasket for pre heat plate(I think this is what it is called. I have tried Rare Spares,Resto Country and Repco with no luck. thanks Bigtone
Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
Are you talking about a 6-cyl HZ ? If so, the one you might be referring to is the hot box gasket, which is sandwiched between the inlet & exhaust manifolds.
That one I have in stock, the EGR one I'm temporarily out of stock.
Dr Terry |
Hi Dr Terry
ists a 253 1978.
regards
Tony
If it's a V8, then the other gasket you need is for the automatic choke heater tubes. Is it the plate that has 2 holes in it ?
Dr Terry |
Thanks Doc
it has two holes.I also sent you a photo to your mobile.
thanks again
Thanks Doc Please let me know when you have them in stock. Regards Tony
