Maca37 Offline
#1 Posted : Monday, 2 December 2024 6:50:45 AM(UTC)
Maca37
Hi all,
anyone know where I could get a EGR valve gasket and the gasket for pre heat plate(I think this is what it is called.
I have tried Rare Spares,Resto Country and Repco with no luck.
thanks
Bigtone
#2 Posted : Monday, 2 December 2024 9:02:42 AM(UTC)
Are you talking about a 6-cyl HZ ? If so, the one you might be referring to is the hot box gasket, which is sandwiched between the inlet & exhaust manifolds.
That one I have in stock, the EGR one I'm temporarily out of stock.
Maca37 Offline
#3 Posted : Monday, 2 December 2024 11:56:26 AM(UTC)
Maca37
Hi Dr Terry
ists a 253 1978.
regards
Tony
#4 Posted : Monday, 2 December 2024 12:56:40 PM(UTC)
If it's a V8, then the other gasket you need is for the automatic choke heater tubes. Is it the plate that has 2 holes in it ?
Maca37 Offline
#5 Posted : Monday, 2 December 2024 2:24:14 PM(UTC)
Maca37
Thanks Doc
it has two holes.I also sent you a photo to your mobile.
thanks again
Maca37 Offline
#6 Posted : Monday, 2 December 2024 5:55:16 PM(UTC)
Maca37
Thanks Doc
Please let me know when you have them in stock.
Regards
Tony
