Joined: 25/12/2006(UTC) Posts: 49  ![Australia Australia]() Location: In the shed Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
My understanding is HT GTS has the adjustable tacho redline & HG GTS does not. Is there any plant to plant variances or dates that mandated the deletion of the adjustable needle? A friend of mine has a very original HT GTS V8 auto without the extra needle, could this be factory correct? Thanks in advance
Thanks: 12 times Was thanked: 11 time(s) in 10 post(s)
Yes that correct, HT Adjustable telltale needle only. HG doesn’t have it. |
j.williams |
Thanks: 3 times Was thanked: 45 time(s) in 44 post(s)
As a general rule that is the difference HT vHG. My HT is June 1970 and has no adjustable needle.
The tachometer is dated May 70 so I am certain that it is original to the car too.
Is your friends a late HT?
Joined: 6/07/2019(UTC) Posts: 472 ![Australia Australia]() Location: bayside Melbourne Thanks: 303 times Was thanked: 40 time(s) in 39 post(s)
Originally Posted by: Verdoro  My understanding is HT GTS has the adjustable tacho redline & HG GTS does not. Is there any plant to plant variances or dates that mandated the deletion of the adjustable needle? A friend of mine has a very original HT GTS V8 auto without the extra needle, could this be factory correct? Thanks in advance have to say.... news to me I don't recall (and I have no pics either) my HT GTS 350 manual having an adjustable tacho redline (and no idea when it was built) |
I believe there are variances to this rule but which plant and dates i dont know
Originally Posted by: Sandaro  As a general rule that is the difference HT vHG. My HT is June 1970 and has no adjustable needle.
Is your friends a late HT? I think its 4th month 70. Which plant was your car built at? Edited by user Saturday, 14 December 2024 8:13:52 AM(UTC)
| Reason: Not specified
Might be difficult if the dash in the car, but with a mirror and torch you can pick up the date code off the back of the tacho. That will give you a 100% answer to whether it is original
It won’t be assembly plant specific. Almost all parts came from the same source and shipped to the assembly plants according to the schedule. I’ve never figured out why and thus when the change occurred. Edited by user Saturday, 14 December 2024 11:08:24 AM(UTC)
| Reason: Not specified |
What about supply issues? When did flexdrive take over from vdo?
If it’s different suppliers it might just be a change in supply contract. |
