Taztiger4 Offline
#1 Posted : Thursday, 2 January 2025 12:31:24 PM(UTC)
Taztiger4
Hi
HJ auto one tonner with later hx manifold & WW Stromberg carb
Where does the trimatic modulator & the distributor get the vacuum source from please
TIA
#2 Posted : Thursday, 2 January 2025 3:52:45 PM(UTC)
If its an auto intake it will have the right brass fitting in it. The one just in front of the distributor will have a nipple on top of it. A short rubber hose between it and the hard vacuum pipe down to the transmission.
Taztiger4 Offline
#3 Posted : Thursday, 2 January 2025 3:57:07 PM(UTC)
Taztiger4
Thanks, and the distributor from a carb port ?
#4 Posted : Thursday, 2 January 2025 4:14:55 PM(UTC)
Yes but make sure its the full vacuum port not the ported one (that the canister uses). you need full vacuum at idle on an auto.
Taztiger4 Offline
#5 Posted : Thursday, 2 January 2025 4:57:30 PM(UTC)
Taztiger4
perfect, thanks again
