Fastlane
Holden Forums
Holden Technical Talk
253 Auto Vacuum source for Trimatic modulator & distributor
Joined: 15/09/2022(UTC) Posts: 99 ![Australia Australia]() Location: Perth Thanks: 41 times
Hi
HJ auto one tonner with later hx manifold & WW Stromberg carb
Where does the trimatic modulator & the distributor get the vacuum source from please
TIA
If its an auto intake it will have the right brass fitting in it. The one just in front of the distributor will have a nipple on top of it. A short rubber hose between it and the hard vacuum pipe down to the transmission. |
Originally Posted by: HK1837  If its an auto intake it will have the right brass fitting in it. The one just in front of the distributor will have a nipple on top of it. A short rubber hose between it and the hard vacuum pipe down to the transmission. Thanks, and the distributor from a carb port ?
Yes but make sure its the full vacuum port not the ported one (that the canister uses). you need full vacuum at idle on an auto. |
Originally Posted by: HK1837  Yes but make sure its the full vacuum port not the ported one (that the canister uses). you need full vacuum at idle on an auto. perfect, thanks again
Fastlane
Holden Forums
