Hi, Can anyone decipher HR firewall plate codes? My HR has the following. BODY: HR225-61252-S TRIM: 1223-E59 PAINT:585-10317 INSERT:D TOP:585-9562
Small fire wall plate: S135512
Engine Number186A62135
I sent these same details to Holden Historical Services. They responded say they were unable to access any Holden archives.As archival material is being relocated from Melbourne to South Australia.
Any help appreciated.
HR225 = Holden HR Special Sedan 61252 = Body number S = Sydney built 1223 = GMH combination code for Grecian White over Cordovan Maroon E59 = Trim number for COPRA & VALSAND FAWN 2-tone interior 585-10317 = Dulux paint code for Cordovan Maroon (Body colour) 585-9562 = Dulux paint code for Grecian White (Top = Roof colour)
S135512 = 135,512th car built in Sydney (Pagewood) since the start of HR production. This includes Chevs, Pontiacs, Bedfords etc, that were built at this time.
186A62135 = Engine number 186 ci 6-cylinder. I think that this is not the original, its number is from an earlier HR.
I believe that the D on the INSERT line was to indicate that a new type of Dulux paint was used.
Thanks: 1 times Was thanked: 629 time(s) in 592 post(s)
The PSN's don't quite work that way Terry. That Pagewood PSN sequence started during HD, roughly around HD chassis number HD09500S and EH (ute) chassis number EH86400S. It restarted and then climbed to about S156000 or so by the end of HR around chassis number HR81000S. The start of Pagewood HR chassis numbers sit around S65000. Pagewood HD chassis numbers start around S090000 and that sequence began early in EH, although there seems to be some weird stuff with EH Pagewood PSN's as the real early cars seem to wear late EJ PSN's up in the S82000's although some EJ are built after the PSN reset. A few 100 bodies into Pagewood EH the PSN is back to S00001. The EH commercials built after HD passenger began also wear the reset HD PSN's. I have EH utes with PSN's up to about S82600. In short S135512 is 135,512 cars that include EH, HD, HR, Bedford, Chevrolet, Pontiac and whatever else GMH were assembling at Pagewood at that time. I agree on the engine, this car should have been around the 186A200000 mark if it was a 186. 186A62135 will be from a HR with a PSN around S086000. Edited by user Tuesday, 21 January 2025 3:21:12 PM(UTC)
| Reason: Not specified |
Thanks for info, much appreciated. I think you’re right in that it’s not the original engine. This HR has been in the family since 1974, purchased second hand from a place in Woodlands Ave Taren Point South of Sydney by my father for $500. I purchased it off my father for $500 in 1990 . I recall when I was a kid - about 10years old- that we dropped the HR off at Higginbottoms at Belmore. For what I thought was a cylinder head replacement. Most likely an exchange engine.
Is it possible to find out how many Cardovan Maroon HR’s were produced? As a keen Holden owner I have only seen a few HR’s in this colour. Cheers
Originally Posted by: 67 Special  Thanks for info, much appreciated. I think you’re right in that it’s not the original engine. This HR has been in the family since 1974, purchased second hand from a place in Woodlands Ave Taren Point South of Sydney by my father for $500. I purchased it off my father for $500 in 1990 . I recall when I was a kid - about 10years old- that we dropped the HR off at Higginbottoms at Belmore. For what I thought was a cylinder head replacement. Most likely an exchange engine.
Is it possible to find out how many Cardovan Maroon HR’s were produced? As a keen Holden owner I have only seen a few HR’s in this colour. Cheers I don't think that information exists anymore. Unless someone stored the GMH IBM360 data before it degraded, and then had a modern IBM capable PC with which to read the database. I only have a small sample of HR's, maybe 1200 cars and there is 5 in that lot. Dr Terry had a HQ Statesman Deville at one stage in Cordovan. |
