Taztiger4 Offline
#1 Posted : Tuesday, 18 February 2025 2:36:32 PM(UTC)
Taztiger4
Hi all
Trying to bleed the brakes HJ 1 Tonner
Disc front, drum rear
Rebuilt master cylinder, Prop valve, booster & front calipers
I bled the master cylinder in the car but its pretty difficlut to remove the temp bleed tubes then connect the hard lines to prop valve without both dripping fluid & possibly letting air re-enter.
Do I need to remove brake fail switch from prop valve whilst bleeding ?
Should I get a decent pedal after just doing rears ?
Thanks in advance
stevo Offline
#2 Posted : Wednesday, 19 February 2025 7:01:41 AM(UTC)
stevo
if the rear shoes are adjusted pretty good you should get half a pedal from just gravity bleeding the system as in open the nipples until fliud comes out,
remove and reset switch after you finish bleeding was how we used to do it. Assuming you have the car jacked up reasonably level.
GM bleed us dry and run away.
 1 user thanked stevo for this useful post.
Taztiger4 on 19/02/2025(UTC)
