holden05 Offline
#1 Posted : Monday, 21 April 2025 12:20:26 PM(UTC)
holden05
I’ve installed a rebuilt master cyl and bled the calipers
The pedal feel is ok but the car will only stop when pedal is at the bottom
Would this be air still in the system or an internal issue with the master?
#2 Posted : Monday, 21 April 2025 9:47:29 PM(UTC)
Was thanked: 40 time(s) in 39 post(s)
the pedal should go hard/harder the more the system is bled (starting with the caliper at LH rear)
.. did it?
stevo Offline
#3 Posted : Tuesday, 22 April 2025 5:57:33 AM(UTC)
stevo
come on mate go and get someone that knows what they are doing to help you and show you whats going on . Its only the brakes its not like you'll get a 2nd chance if something happens. Surely you have a mate that can have a look and help you. I described a problem to some mates once they all said its a bad caliper it turned it it was the booster as soon as one bloke showed up put his foot on the brake he said booster. That would bleed up good until the motor started.
Edited by user Tuesday, 22 April 2025 8:55:06 AM(UTC)  | Reason: Not specified
GM bleed us dry and run away.
202tonner Offline
#4 Posted : Thursday, 24 April 2025 12:20:58 PM(UTC)
202tonner
With my drum brakes if you pump the brake pedal rapidly and it comes 'up' then it is air in the lines. Not sure if the same thing happens with disc brakes! If you rebuilt the master cylinder that was on there before, it probably isn't a problem with that. But I think there are a number of different pushrods which go inside the boosters/master cylinders. So if it is a different m/c this might be what is happening. I'm not sure on any of this, maybe someone out there knows what happens inside the darn things.
Edited by user Friday, 25 April 2025 11:29:50 AM(UTC)  | Reason: Not specified
holden05 Offline
#5 Posted : Thursday, 24 April 2025 4:45:06 PM(UTC)
holden05
It’s not like the car has completley no brakes it just the vehicle only stops when the pedal is almost to the floor. Would I be correct in saying that if it was a master cyl issue then there would be no brakes at all?
#6 Posted : Friday, 25 April 2025 10:29:51 AM(UTC)
It could be that the reaction disc has fallen out inside the booster. Sometimes they stick to the back of the master and come off. Have a read here, not a PBR but close enough:
https://www.classiczcars...pic/43619-reaction-disk/
8D11PCH2 Offline
#7 Posted : Friday, 2 May 2025 8:14:27 AM(UTC)
8D11PCH2
Same with disc brakes, if there is air in the system the pedal will pump up.
 1 user thanked 8D11PCH2 for this useful post.
202tonner on 2/05/2025(UTC)
holden05 Offline
#8 Posted : Wednesday, 7 May 2025 3:23:07 PM(UTC)
holden05
One thing I didn’t do was bench bleed the master
Should I just rebleed at each caliper?
holden05 Offline
#9 Posted : Wednesday, 7 May 2025 3:23:49 PM(UTC)
holden05
