PUNKEE Offline
#1 Posted : Tuesday, 1 July 2025 6:13:12 PM(UTC)
PUNKEE
Hi folks,
I am looking at purchasing a HK GTS, meant to be a genuine 307 car, the code is 80737, is there a way to differentiate if it was a 186 or 307 engined car originally?
Punkee
#2 Posted : Wednesday, 2 July 2025 7:24:33 AM(UTC)
Not from the tags. You have to look hard at the body in a number of places, and I won't divulge that publicly as it helps fakers. If you post up the vehicle's numbers it will narrow down the possibilities but still won't pick it for certain. Is it claimed to be a manual or auto?
PUNKEE Offline
#3 Posted : Wednesday, 2 July 2025 10:15:11 AM(UTC)
PUNKEE
Thanks for the information. It is claimed to be an auto with a two-speed Powerglide transmission. The powerglide is currently in it.
#4 Posted : Wednesday, 2 July 2025 4:58:13 PM(UTC)
Salisbury?
PUNKEE Offline
#5 Posted : Wednesday, 2 July 2025 5:53:46 PM(UTC)
PUNKEE
Yes, meant to be a 10 bolt, I can send you a picture if you like?
#6 Posted : Wednesday, 2 July 2025 8:14:10 PM(UTC)
If its a Salisbury its a V8. If the back seat and tank are out of it post a picture up of the floor in front of the fuel tank and the RH chassis rail in the boot. Also the location of the rear brake hose to solid line bracket above the diff.
PUNKEE Offline
#7 Posted : Thursday, 3 July 2025 1:05:10 PM(UTC)
PUNKEE
Nah, the fuel tank and seat are in it, I can post a picture if you like?
