Joined: 9/06/2025(UTC) Posts: 7 ![Australia Australia]() Location: Melb Thanks: 2 times
Has anyone got a pic of the correct inlet for a late (Jan '78) 4.2 LX Torana? and or some general engine bay area. I'm putting the engine together for a mate, but the engine was incomplete and missing some parts. Thanks,
Joined: 6/07/2019(UTC) Posts: 464 ![Australia Australia]() Location: bayside Melbourne Thanks: 299 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: Todds2  Has anyone got a pic of the correct inlet for a late (Jan '78) 4.2 LX Torana? and or some general engine bay area. I'm putting the engine together for a mate, but the engine was incomplete and missing some parts. Thanks, should be something like this (although I am not sure about the sensor next to the thermostat, think that is a Holden one)  but personally? I would grab a red motor 4BBL 308 inlet manifold (HZ or LX style) and whack a 4BBl Quaddie on it (like they did on the blue XT5 253/4.2 engine in WB and VC) rather than the 2BBL bit of junk Holden put on the 4.2. Yeah I know its not genuine.. but you get a better engine  Edited by user Tuesday, 19 August 2025 9:05:17 AM(UTC)
| Reason: Not specified |
Thanks Smitty2, but the heads on this have the horseshoe exhaust passage in the center, so I assume an EGR valve on an after '76 model. I have seen manifolds with the passage that have a narrow ridge along the side and also one with a 'Log' along the side so thought it would be one of those.
Originally Posted by: Todds2  Thanks Smitty2, but the heads on this have the horseshoe exhaust passage in the center, so I assume an EGR valve on an after '76 model. I have seen manifolds with the passage that have a narrow ridge along the side and also one with a 'Log' along the side so thought it would be one of those. one of these ...??  |
Could be, but could it also be one of these? https://www.fastlane.com...resource.ashx?image=1191Edited by user Tuesday, 19 August 2025 9:39:33 PM(UTC)
Thanks: 1 times Was thanked: 632 time(s) in 594 post(s)
The first one Smitty put up is HT-HG although it’s been drilled for cable throttle (LH, HJ, early LX).
The second one is HZ, VB and really late LX.
There is one in between, HX and middle LX, has big barrels down the sides of the intake pots.
Best bet is grab a HZ, VB or late LX (A9X) 5.0L intake and a Quadrajet off a blue 4.2. Or get a KC 4BBL intake (fits all carby Holden V8) or a Edelbrock Performer. There are also really cheap Chinese knockoffs too but my guess is they won’t fit tight. |
Thanks for that, unfortunately the owner would like it to retain stock appearance, but I'm sure the right combination (and it is an Auto) will be acceptable. The pic I tried to put up must be the middle one with the barrels, so it looks like number two it is. Thanks again for the help guys I'll keep looking for some pics of the engine bay.
It’ll look stock with a 5.0L carby and intake. |
Originally Posted by: HK1837  The second one is HZ, VB and really late LX.
There is one in between, HX and middle LX, has big barrels down the sides of the intake pots. When was the change Byron. Was it right at HZ release ? Dr Terry |
It’ll be close to HZ engine production beginning Terry, around when the pilots started. Possibly like the chassis changes. |
Joined: 7/08/2025(UTC) Posts: 6 ![Australia Australia]() Location: Victoria Was thanked: 1 time(s) in 1 post(s)
Can anyone tell me on a 12/77 4.2 v8 manual van what the intake manifold numbers are please? 9932888 or 9945690-88 ? Also the carb number of the 2 barrel? 23-3111 or 23-3112? Like to get the right parts before rebuilding engine
Can't help with the manifold casting number but carby no. 23-3112 is correct for a 4.2 V8 manual. The 23-3111 is for the auto.
Dr Terry |
Great thanks dr terry…… I have a few manifolds here on engines the 23-3112 that’s bolted to manifold 9932888 looks very dirty and untouched (original looking) …. I do have the gmh parts book I need to look up, manifold but couldn’t find info on Carbies with 23- 3112 ect ect. Also this said manifold has the egr valve blanked off…. Where as the 23-3111 carbed manifolds have the egr fitted….. did manual cars run the egr valve?
Thanks hk1837, thought this may be the case… any idea what color tailshaft the hz 253 m20 manual vans were? Im lead to believe light blue?
Originally Posted by: Hdt333  Thanks hk1837, thought this may be the case… any idea what color tailshaft the hz 253 m20 manual vans were? Im lead to believe light blue? No but I’ll look it up in a few days, busy right now. Just about all V8 HQ to WB van & ute used the same tailshaft so plenty around. The only odd one out is HJ to about 5/79 5.0L auto, rest are all the same. |
My records show all HQ-HZ V8 SWB (exc. TH400) have a white painted tailshaft.
Dr Terry |
Thanks for the help gentleman, it’s much appreciated
 1 user thanked Hdt333 for this useful post.
Joined: 2/03/2018(UTC) Posts: 129  ![Australia Australia]() Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: Dr Terry  My records show all HQ-HZ V8 SWB (exc. TH400) have a white painted tailshaft.
Dr Terry Ii don't have any books to look at, but but my memory (from years ago, so i hope its correct) says white tailshaft was sedan & van/ute was dk blue.
That is correct, white is the short wheelbase (111") V8 tailshaft, ie Holden sedan and coupe.
The standard (or mid) 114" wheelbase V8 tailshaft (ute, van and wagon plus manual Statesman) for all engines and boxes except for TH400 in HJ to HZ was Dark Blue. The HQ V8 Statesman models (81469 and 81669) with Trimatic used a different part number tailshaft 9930700 which was Pink, but was the same length, same unis, same OD and same wall thickness as the white shaft (p/n 2814340). The HQ Engineering Technical Specs show the pink one as a 2-piece tailshaft with centre bearing. A standard V8 Statesman or one optioned with M20 or M21 used the white tailshaft but if it was optioned with Trimatic it got a pink shaft like the standard HQ Deville. Or so the Engineering Technical Specs say, I have never seen one. My first drive car in 1984 was a 3/74 HQ Deville, it never had a two piece tailshaft. The May 1977 HQ parts catalogue shows the same thing, ie a pink shaft for auto V8 Statesman. Given its a 993 part number I'm wondering if it was updated for export HJ Deville with 4.2 Trimatic? The T-bar was changed to cable type for Statesman only in the mid 70's to eliminate vibration, and also the 2.78 Salisbury was first replaced with 2.60 in HJ Statesman to reduce noise. So maybe this pink shaft was done for similar reasons?
As a comparison the 6cyl models in the 114" wheelbase are a bit different, manual ones use a Light Bronze green shaft and Trimatic ones are Light Blue. The length and unis and wall thickness are the same, but the length is different by 0.01" (Light Blue shorter) and the diameter is 3" for manual and 2.75" for auto. |
