Todds2 Offline
#1 Posted : Tuesday, 19 August 2025 8:53:28 AM(UTC)
Todds2
Has anyone got a pic of the correct inlet for a late (Jan '78) 4.2 LX Torana? and or some general engine bay area. I'm putting the engine together for a mate, but the engine was incomplete and missing some parts.
Thanks,
#2 Posted : Tuesday, 19 August 2025 9:00:42 AM(UTC)
Thanks,
should be something like this (although I am not sure about the sensor next to the thermostat, think that is a Holden one)
but personally?
I would grab a red motor 4BBL 308 inlet manifold (HZ or LX style) and whack a 4BBl Quaddie on it (like they did on the blue XT5 253/4.2 engine in WB and VC)
rather than the 2BBL bit of junk Holden put on the 4.2. Yeah I know its not genuine.. but you get a better engine Applause
Edited by user Tuesday, 19 August 2025 9:05:17 AM(UTC)  | Reason: Not specified
Todds2 Offline
#3 Posted : Tuesday, 19 August 2025 5:18:45 PM(UTC)
Todds2
Thanks Smitty2, but the heads on this have the horseshoe exhaust passage in the center, so I assume an EGR valve on an after '76 model. I have seen manifolds with the passage that have a narrow ridge along the side and also one with a 'Log' along the side so thought it would be one of those.
#4 Posted : Tuesday, 19 August 2025 9:06:41 PM(UTC)
one of these ...??
Todds2 Offline
#5 Posted : Tuesday, 19 August 2025 9:38:08 PM(UTC)
Todds2
Could be, but could it also be one of these?
https://www.fastlane.com...resource.ashx?image=1191
Edited by user Tuesday, 19 August 2025 9:39:33 PM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, 20 August 2025 3:53:21 PM(UTC)
The first one Smitty put up is HT-HG although it’s been drilled for cable throttle (LH, HJ, early LX).
The second one is HZ, VB and really late LX.
There is one in between, HX and middle LX, has big barrels down the sides of the intake pots.
Best bet is grab a HZ, VB or late LX (A9X) 5.0L intake and a Quadrajet off a blue 4.2. Or get a KC 4BBL intake (fits all carby Holden V8) or a Edelbrock Performer. There are also really cheap Chinese knockoffs too but my guess is they won’t fit tight.
Todds2 Offline
#7 Posted : Wednesday, 20 August 2025 5:21:50 PM(UTC)
Todds2
Thanks for that, unfortunately the owner would like it to retain stock appearance, but I'm sure the right combination (and it is an Auto) will be acceptable. The pic I tried to put up must be the middle one with the barrels, so it looks like number two it is. Thanks again for the help guys I'll keep looking for some pics of the engine bay.
#8 Posted : Wednesday, 20 August 2025 5:44:22 PM(UTC)
It’ll look stock with a 5.0L carby and intake.
#9 Posted : Wednesday, 20 August 2025 6:02:19 PM(UTC)
When was the change Byron. Was it right at HZ release ?
#10 Posted : Thursday, 21 August 2025 12:01:16 AM(UTC)
It’ll be close to HZ engine production beginning Terry, around when the pilots started. Possibly like the chassis changes.
Hdt333 Offline
#11 Posted : Sunday, 7 September 2025 11:20:54 PM(UTC)
Hdt333
Can anyone tell me on a 12/77 4.2 v8 manual van what the intake manifold numbers are please? 9932888 or 9945690-88 ? Also the carb number of the 2 barrel? 23-3111 or 23-3112? Like to get the right parts before rebuilding engine
#12 Posted : Monday, 8 September 2025 7:20:26 AM(UTC)
Can't help with the manifold casting number but carby no. 23-3112 is correct for a 4.2 V8 manual. The 23-3111 is for the auto.
Hdt333 Offline
#13 Posted : Monday, 8 September 2025 11:54:30 AM(UTC)
Hdt333
Great thanks dr terry…… I have a few manifolds here on engines the 23-3112 that’s bolted to manifold 9932888 looks very dirty and untouched (original looking) …. I do have the gmh parts book I need to look up, manifold but couldn’t find info on Carbies with 23- 3112 ect ect. Also this said manifold has the egr valve blanked off…. Where as the 23-3111 carbed manifolds have the egr fitted….. did manual cars run the egr valve?
#14 Posted : Monday, 8 September 2025 8:52:59 PM(UTC)
Only auto had EGR.
Smitty2 on 9/09/2025(UTC)
Hdt333 Offline
#15 Posted : Tuesday, 9 September 2025 12:31:37 AM(UTC)
Hdt333
Thanks hk1837, thought this may be the case… any idea what color tailshaft the hz 253 m20 manual vans were? Im lead to believe light blue?
#16 Posted : Tuesday, 9 September 2025 6:16:06 AM(UTC)
No but I’ll look it up in a few days, busy right now. Just about all V8 HQ to WB van & ute used the same tailshaft so plenty around. The only odd one out is HJ to about 5/79 5.0L auto, rest are all the same.
#17 Posted : Tuesday, 9 September 2025 8:48:50 AM(UTC)
My records show all HQ-HZ V8 SWB (exc. TH400) have a white painted tailshaft.
Smitty2 on 11/09/2025(UTC)
Hdt333 Offline
#18 Posted : Tuesday, 9 September 2025 9:36:28 PM(UTC)
Hdt333
Thanks for the help gentleman, it’s much appreciated
 1 user thanked Hdt333 for this useful post.
HK-Q-Z5.0Lfan Offline
#19 Posted : Thursday, 11 September 2025 3:25:45 PM(UTC)
HK-Q-Z5.0Lfan
Ii don't have any books to look at, but but my memory (from years ago, so i hope its correct) says white tailshaft was sedan & van/ute was dk blue.
#20 Posted : Friday, 12 September 2025 3:36:33 PM(UTC)
That is correct, white is the short wheelbase (111") V8 tailshaft, ie Holden sedan and coupe.
The standard (or mid) 114" wheelbase V8 tailshaft (ute, van and wagon plus manual Statesman) for all engines and boxes except for TH400 in HJ to HZ was Dark Blue. The HQ V8 Statesman models (81469 and 81669) with Trimatic used a different part number tailshaft 9930700 which was Pink, but was the same length, same unis, same OD and same wall thickness as the white shaft (p/n 2814340). The HQ Engineering Technical Specs show the pink one as a 2-piece tailshaft with centre bearing. A standard V8 Statesman or one optioned with M20 or M21 used the white tailshaft but if it was optioned with Trimatic it got a pink shaft like the standard HQ Deville. Or so the Engineering Technical Specs say, I have never seen one. My first drive car in 1984 was a 3/74 HQ Deville, it never had a two piece tailshaft. The May 1977 HQ parts catalogue shows the same thing, ie a pink shaft for auto V8 Statesman. Given its a 993 part number I'm wondering if it was updated for export HJ Deville with 4.2 Trimatic? The T-bar was changed to cable type for Statesman only in the mid 70's to eliminate vibration, and also the 2.78 Salisbury was first replaced with 2.60 in HJ Statesman to reduce noise. So maybe this pink shaft was done for similar reasons?
As a comparison the 6cyl models in the 114" wheelbase are a bit different, manual ones use a Light Bronze green shaft and Trimatic ones are Light Blue. The length and unis and wall thickness are the same, but the length is different by 0.01" (Light Blue shorter) and the diameter is 3" for manual and 2.75" for auto.
Guest (10)
This page was generated in 0.213 seconds.
