ArtemisLDS Offline
#1 Posted : Monday, 23 March 2026 11:25:43 PM(UTC)
ArtemisLDS
Hi everyone
New here.
I'm working on fixing a friend's car, and I'm almost done, just a few last things to go.
Friend's car is a Holden Barina TM 2012.
Some history:
Friend's car would shake violently when idling.
They mentioned oil leak, so they topped up.
I believe they overfilled, and also, it was leaking engine oil as the spark plug wells were full of oil.
So I've drained the oil, replaced it with new.
Replaced oil filter.
Replaced spark plugs (they were also in very bad condition) and coil pack (it was slightly damaged/worn).
Replaced engine cover gasket.
So far no more leaks, drives smoother, but idles still a little rough, especially when using AC.
Particularly when using AC, engine light comes on if idling too long, or slow driving - random/multiple misfires detected.
Turn off AC and light goes away, or with AC on, when cruising, no light.
So seems to be a lack of power somewhere.
Which leads to this noise I hear when doing slow accelerations, sounds like the engine is struggling a little.
https://youtube.com/shorts/puQu22IfOuk
Finally, I also noticed, when AC is on, brakes get stuck (so if you pump the brakes before starting the car, and you get that stiff stuck feeling, that's what I feel) when doing slow menuveurs, such as park or 3 point turns.
Turn off AC and it slowly goes back to normal.
AC on, it'll happen again, but doesn't happen during regular driving.
Read on Google it relates to not enough power or something, boost or rather, for brakes to function properly.
So I feel like there's a common theme going on, hoping someone os able to advise what it is exactly, and how to fix.
#2 Posted : Tuesday, 24 March 2026 4:06:02 PM(UTC)
The TM Barina is a pretty good reliable little car, especially when compared to the older (Opel) versions.
The only regular fault we see on these is a leaking PCV valve, which is part of the rocker cover.
The main reason I mention this is that it mainly effects idle quality.
ArtemisLDS Offline
#3 Posted : Tuesday, 24 March 2026 5:59:50 PM(UTC)
ArtemisLDS
Is there a way I can test for the leak?
Otherwise, presuming the leak, would it cause brakes to not engage properly, or get stuck, when doing slow menuveurs with AC on?
#4 Posted : Wednesday, 25 March 2026 5:15:15 AM(UTC)
I'm not sure what you mean by the brakes getting "stuck", but the brake booster is badly effected by low or erratic manifold vacuum.
Check the PCV plumbing & temporarily block it off to see if it changes the idle speed or quality.
Edited by user Wednesday, 25 March 2026 5:15:59 AM(UTC)  | Reason: Not specified
ArtemisLDS Offline
#5 Posted : Wednesday, 25 March 2026 6:45:20 AM(UTC)
ArtemisLDS
Thank you Dr Terry
Will have a look at those
As for stuck, so before turning on the car, if you pump the brakes, after a few tubes, they get this hard, stiff feeling.
It's that same feeling when AC is on and performing slow menuveurs.
I have to push really hard in, even though it doesn't feel like it's going any further, just for the car too slow and stop.
#6 Posted : Wednesday, 25 March 2026 4:09:45 PM(UTC)
Originally Posted by: ArtemisLDS Go to Quoted Post
Thank you Dr Terry
It does sound like you are losing vacuum, this is exactly what your pedal will do. When the A/Cond is on, the engine vacuum will be even lower, making the problem worse.
I would get a good mechanic to look at it, the brake booster itself may be faulty also, but again it's easy for a pro to check.
ArtemisLDS Offline
#7 Posted : Thursday, 26 March 2026 7:38:45 AM(UTC)
ArtemisLDS
Thank you Dr Terry
Was hoping it'd be ready things for me to check and fix lol
Just trying to avoid the mechanic where possible, due to time constraints
I'll have the car back next week or so apparently, will go from there
ArtemisLDS Offline
#8 Posted : Friday, 10 April 2026 3:03:55 PM(UTC)
ArtemisLDS
Finally got it to the mechanic today, as I need to do a road worthy check before I can register the vehicle to me.
Mechanic doesn't believe it's vacuum leak, doesn't display the typical symptoms, but tested the cylinder compression where the spark plugs are.
Cylinders 1 and 4 hit 200 (don't know the unit used)
Cylinders 2 and 3 hit only 125.
He mentioned the car must have overheated at one stage, causing something to go bad between cylinders 2-3, to which now I remember my friend saying it has shut off due to overheating on the road before.
So I don't quite have the finance to take the engine head/block out to have it fixed, I guess any options?
Do additives works?
Stuff that claim to stop leaking, restore compression, etc?
8D11PCH2 Offline
#9 Posted : Tuesday, 14 April 2026 6:35:47 AM(UTC)
8D11PCH2
Do additives works?
I believe there is testing equipment out there that mechanics should have to test for combustion gasses getting into the cooling system.
Otherwise it's remove the cylinder head to check for a blown head gasket.
#10 Posted : Tuesday, 14 April 2026 8:16:09 PM(UTC)
yeah I have a thing a tool called TeeKay
Tee-Kay Head Check Combustion Leak Detector - TK01
works a treat!
https://wbtools.com.au/p...tion-leak-detector.html
#11 Posted : Thursday, 16 April 2026 2:20:37 PM(UTC)
Sounds like you should avoid buying the car. May be cheap to huy, but the tepairs sound expensive
ArtemisLDS Offline
#12 Posted : Thursday, 16 April 2026 5:15:30 PM(UTC)
ArtemisLDS
In hindsight, yes, probably not worth it.
But it is the only immediate vehicle I have to use.
Originally I was going to just fix it and give it to them to use.
Then they said they didn't want it and was going to get a new car.
So was going to give it to them to use while they look for the new car.
Then they said they didn't need it for now, and I can have it instead.
So now I'm trying to get it fixed up and not just in running condition.
All I have left to do is this compression issue, which I hope the Nulon Engine Repair additive I found will help a little (says helps restore compression - dunno if that means it'll help temporarily fill in any gaps or something), and a new coolant reservoir (has cracks and leaking when under pressure - or I might just try gluing the whole bottom side to stop the leak).
And this should hopefully tie me over until I can get a proper new car.
Guest (19)
This page was generated in 0.105 seconds.
