holden05 Offline
#1 Posted : Friday, 27 March 2026 7:35:50 PM(UTC)
holden05
I’ve just recieved my master cylinder back from Burt bros. When I asked about bench bleeding they said there was no need. “Just mount it up and bleed it like normal”
Does this sound right?
#2 Posted : Saturday, 28 March 2026 9:06:49 AM(UTC)
It will work either way.
I prefer to bench bleed first. It is less messy & you know it is fully bled before fitting. You will then only need 1 or 2 pumps after fitting, unless of course you want to fully bleed to the wheels.
holden05 Offline
#3 Posted : Saturday, 28 March 2026 9:26:33 AM(UTC)
holden05
Hi Dr Terry
I was intending in bolting up “dry” and vacuum power bleeding the whole system at each wheel. Burt’s are saying that as it’s a non pressure line . Does my method sound ok
#4 Posted : Sunday, 29 March 2026 2:35:30 PM(UTC)
It takes 5 minutes to bench bleed. Do that first to make the whole bleeding procedure quicker & easier.
holden05 Offline
#5 Posted : Sunday, 19 April 2026 9:58:21 AM(UTC)
holden05
I’ve bled the master up ok but I’m unsure what a “good” pedal feels like
A first I thought I had a booster issue. I’ve started and ran the car for a few minutes. Turn off and pumped the pedal, after 5 pumps the vac is depleted and the pedal is hard
Then turned the car on and the pedal will sink approx 3-4cm and then becomes firm
Does this sound normal or am I expecting too much from a 40
Yr old brake tech?
#6 Posted : Sunday, 19 April 2026 11:52:13 AM(UTC)
Yr old brake tech?
Most of that sounds quite normal. What model series are we talking here? Some are better than others, I remember early HK had a very low pedal.
It also depends what the rest of the brakes are like. For example, if the pads are new, or the rears are not yet bedded & adjusted this will have a huge effect on the pedal height.
Dr Terry.
holden05 Offline
#7 Posted : Sunday, 19 April 2026 3:14:46 PM(UTC)
holden05
It’s a vc
#8 Posted : Sunday, 19 April 2026 6:15:25 PM(UTC)
Yes of course the brake pedal will go hard with the engine off. Take the car for a tentative test drive and feel them out. Do they work???? Question answered!
Guest (6)
