Joined: 2/03/2018(UTC) Posts: 129  ![Australia Australia]() Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
G'day, HX has developed a couple leaks from sitting around. As I dont have a lot of faith in google &/or the local auto places, could someone please supply the part numbers (that a bearing shop would recognise) for Saginaw rear seal & Salisbury pinion seal.
Cheers for any help
These guys sell a seal kit for Saginaw 4spd, will have the selector seals and probably the speedo drive seal. https://www.ebay.com.au/...D%7Ctkp%3ABk9SR_qN8KmoZwHere is a 10-bolt front seal. Dr Terry will probably have a better idea of aftermarket part numbers. |
Joined: 6/07/2019(UTC) Posts: 471 ![Australia Australia]() Location: bayside Melbourne Thanks: 303 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: HK1837  These guys sell a seal kit for Saginaw 4spd, will have the selector seals and probably the speedo drive seal. https://www.ebay.com.au/...D%7Ctkp%3ABk9SR_qN8KmoZwHere is a 10-bolt front seal. Dr Terry will probably have a better idea of aftermarket part numbers. I get my diff stuff (inc gaskets and seals) from diff shops... eg Diff Technics or GJ diffs but I quote the GMH part number when talking to them The pinion seal on the GMH local 'big' Salisbury aka 10 bolt is PN #7449859 per my GMPA records but this was superseded when VK came out with PN #92022920 HTH |
