HK-Q-Z5.0Lfan Offline
#1 Posted : Tuesday, 31 March 2026 1:56:12 PM(UTC)
HK-Q-Z5.0Lfan
G'day,
HX has developed a couple leaks from sitting around. As I dont have a lot of faith in google &/or the local auto places, could someone please supply the part numbers (that a bearing shop would recognise) for Saginaw rear seal & Salisbury pinion seal.
Cheers for any help
#2 Posted : Tuesday, 31 March 2026 4:43:54 PM(UTC)
These guys sell a seal kit for Saginaw 4spd, will have the selector seals and probably the speedo drive seal.
https://www.ebay.com.au/...%7Ctkp%3ABk9SR_qN8KmoZw
Here is a 10-bolt front seal.
Dr Terry will probably have a better idea of aftermarket part numbers.
Smitty2 on 31/03/2026(UTC)
#3 Posted : Tuesday, 31 March 2026 5:52:50 PM(UTC)
I get my diff stuff (inc gaskets and seals) from diff shops... eg Diff Technics or GJ diffs
but
I quote the GMH part number when talking to them
The pinion seal on the GMH local 'big' Salisbury aka 10 bolt is PN #7449859 per my GMPA records
but this was superseded when VK came out with PN #92022920
HTH
