holden05 Offline
#1 Posted : Sunday, 19 April 2026 3:30:29 PM(UTC)
holden05
This is what I have
Interior light
Radio
Hazard lights
This is what I don’t have
Brake lights
Headlight, albeit hi beam when I flick the stalk
Not sure where to start
#2 Posted : Wednesday, 22 April 2026 11:11:01 AM(UTC)
Start with a circuit diagram & a test light.
There is is no common link between those 2 circuits other than the fusebox itself.
The headlights (except the the hi-beam flasher) are supplied thru fuse 1 & the brake lights are supplied thru fuse 3.
Edited by user Wednesday, 22 April 2026 11:13:12 AM(UTC)  | Reason: Not specified
Smitty2 on 22/04/2026(UTC)
holden05 Offline
#3 Posted : Thursday, 23 April 2026 8:08:48 PM(UTC)
holden05
Also no indicators and the relay isn’t clicking
#4 Posted : Friday, 24 April 2026 2:31:00 PM(UTC)
Blinkers are supplied from fuse no. 5.
It's time for a good look at the fusebox.
holden05 Offline
#5 Posted : Friday, 24 April 2026 2:53:18 PM(UTC)
holden05
Yep. Plan is to swap out the bullet fuses
holden05 Offline
#6 Posted : Saturday, 25 April 2026 5:00:36 PM(UTC)
holden05
Have a a wiring diagram and multimeter
Going to spend time on it tommorow
I can see where the fusable link is
My question is if that link is broken would I get no electric in the car?
#7 Posted : Sunday, 26 April 2026 8:50:44 AM(UTC)
If the fusible link has gone open circuit it cuts all power to every circuit, except the main starter lead.
One other thing, when chasing electrical harness faults especially fuses & switches etc, it's better to use a test light, not a multimeter. A multimeter will lead you astray, because it's not reading 12V under load.
Use a good old fashioned incandescent lest light, not a LED one. The LED type will do the same as a multimeter.
holden05 Offline
#8 Posted : Sunday, 26 April 2026 2:19:30 PM(UTC)
holden05
Problem solved
Bad earth at radiator
