Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
This is what I have Interior light Radio Hazard lights
This is what I don’t have Brake lights Headlight, albeit hi beam when I flick the stalk
Not sure where to start
Start with a circuit diagram & a test light. There is is no common link between those 2 circuits other than the fusebox itself. The headlights (except the the hi-beam flasher) are supplied thru fuse 1 & the brake lights are supplied thru fuse 3. Dr Terry Edited by user Wednesday, 22 April 2026 11:13:12 AM(UTC)
| Reason: Not specified |
Also no indicators and the relay isn’t clicking
Originally Posted by: holden05  Also no indicators and the relay isn’t clicking Blinkers are supplied from fuse no. 5. It's time for a good look at the fusebox. Dr Terry |
Yep. Plan is to swap out the bullet fuses
Have a a wiring diagram and multimeter Going to spend time on it tommorow I can see where the fusable link is My question is if that link is broken would I get no electric in the car?
Originally Posted by: holden05  Have a a wiring diagram and multimeter Going to spend time on it tommorow I can see where the fusable link is My question is if that link is broken would I get no electric in the car? If the fusible link has gone open circuit it cuts all power to every circuit, except the main starter lead. One other thing, when chasing electrical harness faults especially fuses & switches etc, it's better to use a test light, not a multimeter. A multimeter will lead you astray, because it's not reading 12V under load. Use a good old fashioned incandescent lest light, not a LED one. The LED type will do the same as a multimeter. Dr Terry |
Problem solved Bad earth at radiator
